Coils on top of spacers info
Old Jan 28, 2010 | 03:58 PM
ram man17's Avatar
ram man17
Default Coils on top of spacers info
I recieved this in the mail last night,
3" shackles for the rear and 3" coils for the front.
I also have 2.5" daystar coil spacers...
I dropped the truck off at the shop this morning only to pick it up exactly the same
They informed me that you cant put the 2.5" spacers on top of the 3" coils, that there simply isnt enough room.
Then they tried just the 3" coils with nothing in the rear and they said it sat lower in the front than it did when it came in... that makes no sense, 3>2.5
So for a heads up to guys (maybe just 2wd) that are planning on running coils with spacers. A smaller spacer might have worked but a 2.5" one will not fit.
Old Jan 28, 2010 | 04:05 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Yeah, I think you would have to find a 3" longer spindle for the front then you should be able to run the spacer, right? With a stock spindle, you just couldn't fit 5.5 inches of lift in there.
Old Jan 28, 2010 | 04:16 PM
ram man17's Avatar
ram man17
The longer spindles are 4" and about $600
Shiloh 24's Avatar
Shiloh 24
I would agree, there just isn't enough room in there to fit that much. With taller spindles I'm sure it could be done easily and without problems. As for the 3" coil sitting lower that the stock with a 2.5" spacer I think he's pullin your chain unless you got stiffed on the coils you bought.
Old Jan 28, 2010 | 06:12 PM
ram man17's Avatar
ram man17
I agree Shiloh. Im not quite sure about the whole deal. But I just wanted to give everyone a heads up
Old Jan 28, 2010 | 10:10 PM
OlDirtyJohn's Avatar
OlDirtyJohn
dude, you wouldnt stack multiple spacers would you? then why would you think you could use a longer coil and a spacer? longer coils do exactly the same thing as a spacer. theres no way in hell you could ever get both to work together. even with lift spindles. (lift spindles arent longer, they just move the wheel lower on the spindle, thus raising the front end)
so you need to ditch one of the two, and settle with just being leveled, or get some spindles, and use those with either the spacer or coil, but not both.
Old Jan 28, 2010 | 10:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As said before and as I already have, you need 3-4" spindles and then the 3" coil. Works for me just fine.
Old Jan 28, 2010 | 10:51 PM
ram man17's Avatar
ram man17
True, and i found that out the hard way. Im just gonna settle with keepin it leveled.
And this thread is for any newb out there haha before you go and ask a leveling question read Ol Dirty John's post! and dont make the same mistake I did
Old Jan 28, 2010 | 10:53 PM
ram man17's Avatar
ram man17
and weed when the shop told me the exact same thing you did, they said that instead of using my coils and stuff, they could do a body lift for a grand haha! you could get a 6" suspension lift for that price
Old Jan 29, 2010 | 06:41 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Hey, like others here, I did my BL all by myself. You can always come up here one weekend and we can do it. Ive got everything we need.
