beeping issue and engine light
Old Jan 29, 2010 | 04:16 PM
mopardodge1500's Avatar
mopardodge1500
Default beeping issue and engine light
i have a 2003 dodge ram 1500 with the 5.9L, now there seems to be an extremely loud beeping noise every once in a while its 4 loud beeps in a row never happened before.
also my engine light is always on now, not to sure why though, everything is working fine.
i dont think the beeps have anything to do with the engine light because the engine light was on before and there was no beeps so why all of a sudden the damn beeps?
Tyler
Old Jan 29, 2010 | 05:00 PM
nim81's Avatar
nim81
do any lights blink with the beeping? could be your battery starting to go south, i know my electronics go wild and i get a beeping when the batt goes dead. you should also check to see why the engine light is on. i would do that first!
Old Jan 29, 2010 | 05:15 PM
mopardodge1500
nothing happens when the beeping occurs, it just beeps 4 times. how and what do i do to see what the engine light problem is? could this be a major problem or something that can wait.
Old Jan 29, 2010 | 05:19 PM
nim81's Avatar
nim81
it really depends why its on, if your truck isnt running badly or anything it probably isnt major but definitely needs checked out. try turning the key on-off 3 times ending in the on position. should read a code out on the odometer. if that dont work most auto-parts stores will check the code for free.
Old Jan 29, 2010 | 05:24 PM
mopardodge1500
my truck is giving me two codes po141 and po138 i dont know what either of them are?
Old Jan 29, 2010 | 05:29 PM
nim81's Avatar
nim81
po141 is #1 O2 sensor relay ,
po138 #1 02 sensor shorted to voltage.
sounds like an 02 problem, i would think that would cause any beeping though.
check all the wiring to the #1 o2 sensor make sure its not cut or any bare wire showing anywhere.
Old Jan 29, 2010 | 05:32 PM
mopardodge1500
great! thanks. where in the engine bay would this sensor be located its a 5.9L if that makes any difference.
Old Jan 30, 2010 | 09:44 AM
nim81's Avatar
nim81
it will be the one before the cat, or if you have sensors on each exhaust manifold it would be the driverside
Old Jan 30, 2010 | 01:46 PM
lxman1's Avatar
lxman1
Site Moderator
Sometimes, I have seen a burned out airbag light cause a beep to warn that it doesn't work. Not sure if Dodge does this or not.
Old Jan 30, 2010 | 03:28 PM
mopardodge1500
okay great, ill look later on today to find the sensors, and let you know
Tyler
