Are tire brands that much different in size?
Old Jan 30, 2010 | 09:59 AM
hoss67's Avatar
hoss67
Default Are tire brands that much different in size?
So i am running 285/70/17 which should be a 32.8 inch tire. I rolled the same size tire but it was a BFG KM2 up next to it. It was about 2.5 inches higher, granted my tires don't have much tread wear left, but it shouldn't be 2.5 inches different?
Old Jan 30, 2010 | 10:25 AM
MikeHTally's Avatar
MikeHTally
Are you talking about tires with no load on 'em, or are your tires mounted on the truck with load on the suspension? I suspect if you compare two unmounted new tires, there won't be much difference.
Old Jan 30, 2010 | 10:36 AM
hoss67's Avatar
hoss67
yea they dont have much tread at all..... like i also checked the specs of the tires, the discover stt tires i got on now say they arte 32.8 but the bfg's say they are 33's but the tires on my truck i measured are like 31 inches.
Old Jan 30, 2010 | 11:06 AM
matthewbeard's Avatar
matthewbeard
if you measured the size yourself while the truck tire was mounted and on the truck especially the front it will be off. the weight of the engine will compress the tires down
Old Jan 30, 2010 | 12:20 PM
formguy's Avatar
formguy
Tires vary wildly by manufacturer. My 33" TRXUS M/Ts were easily 2" taller than my Cooper STTs. The Smallest ones I had were F/C IIs . 33x12.5 was smaller in height than stock
Old Jan 30, 2010 | 12:22 PM
hoss67's Avatar
hoss67
was ur discover stt 33" as well? cause thats what i have right now?
Old Jan 30, 2010 | 01:36 PM
mdram43's Avatar
mdram43
ive got the same size tires, terra grapplers, they looked huge before they were mounted, and mounted there something like 32.5" tall, i taped em.
Old Jan 30, 2010 | 02:36 PM
MikeHTally's Avatar
MikeHTally
Wheel width could have an effect -- 285/70x17 will have a specific diameter, regardless of manufacturer. 285 x .7 x 2 = 399mm. 399/25.4 = 15.71". 15.71+17= 32.71" in diameter.
