I think my Leveling Kit is WRONG!!!!
Old Jan 30, 2010 | 05:21 PM
Solid_Crimson28's Avatar
Solid_Crimson28
Default I think my Leveling Kit is WRONG!!!!
Someone please help... I ordered a 2 inch leveling kit from tuff country. I have a 2006 dodge ram quad 4x4. I assumed that they would be 2 inches thick, but i measured them and they are exactly 1 inch thick... could they have sent me the wrong Kit?
Old Jan 30, 2010 | 05:25 PM
cwboyjohnny24's Avatar
cwboyjohnny24
I didn't lift with a spacer, but I'm pretty sure the spacer should be 2" tall!! If you got a receipt or packing list with it, double check the part number it should've been on the packing slip to the part and the box/packaging it came in. You could even double check the part number on the package to the website part number you ordered. Other than that, call 'em. They may send you the right part and tell you to keep those. Then you have a free ebay item.
Old Jan 30, 2010 | 06:29 PM
LanceFuson's Avatar
LanceFuson
I think you got the right one I asked that once and the dealers said that's the way they come. when it is put in it apparently gives you the 2" lift some how.
Old Jan 30, 2010 | 06:33 PM
cwboyjohnny24
Check this thread out. There's a picture of him measuring a 2" lift spacer.
https://dodgeforum.com/forum/3rd-gen...eling-kit.html
Old Jan 30, 2010 | 07:57 PM
jumbonas's Avatar
jumbonas
sounds about right, i copied and made a 2.5 and honestly it was too much, should have went with about 2", in that post, it states it actually lifted it 3 in. the suspension has an angle of attack, therefore has a ratio not 1:1 with the height gain, plus it is inboard of the wheel. so less than 2" will yield 2" at the wheel
Old Jan 30, 2010 | 09:19 PM
AsphaltCowboy's Avatar
AsphaltCowboy
well my leveling kit has lost some height after it settled. is installed yet? if so, for how long?
Old Jan 30, 2010 | 09:31 PM
Unperfected's Avatar
Unperfected
yah its right it will prob give you just under 2". I made mine myself, i called a company and they told me theres were 1 and a half and i made it that size and got abot 2 1/2 of lift
Old Jan 30, 2010 | 11:05 PM
Solid_Crimson28
thanks for the help guys...so let me get this straight it sounds right that the spacers are an inch thick to get 2 inches? I just wanna be sure. how could i make my own???
