Drivers door weather stripping Leaking air
Old Jan 31, 2010 | 09:44 AM
mpk4580's Avatar
mpk4580
Default Drivers door weather stripping Leaking air
Has anyone had a problem with a door leaking air over 40mph. I thought it was my window so I installed in channel ventshades to tighten up the seal but that did not work. Yesterday driving in this wonderful New England 10 degree weather , I could hear air coming thru I pulled the door tighter and it seemed to stop the air leaking. Is there a way to tighten the door seal or do I have to replace it. Thanks
Old Jan 31, 2010 | 10:00 AM
hain84's Avatar
hain84
yes i also have this problem. its like the door is loose and not getting a good seal. its something i have come to live with as it doesnt seem anything is loose or out of adjustment on mine. Maybe there is i just never took it to checked out either.
Old Jan 31, 2010 | 10:38 AM
jayjma's Avatar
jayjma
i also have this problem but mine is the passenger door, but again everything seems fine nothing loose no damage to the stripping. i don't know if there is anything we could add? mine doesn't do it all the time but when it does its annoying as hell
Old Jan 31, 2010 | 10:49 AM
dirtydog's Avatar
dirtydog
Moderate User
Is the air leak above the door handle? Like towards the top? Only solutions that have worked is either to replace the weather stripping $$$$$$ or put your window down and try to bend the top in towards the cab. put your knees into the door panel and pull inwards. I've done that on a few vehicles and it works great.
if you bring it to a garage or a dealer they would do the same thing and charge an hour for diagnostics likely.
Old Jan 31, 2010 | 10:53 AM
BadHab1t's Avatar
BadHab1t
weed said stripping for the doors at the dealer were only like 20 bucks mine have rips from the door closing right by the mirror and i was gonna get new ones but im scared the news are gonna do the same thing.....
Old Jan 31, 2010 | 01:16 PM
dirtydog's Avatar
dirtydog
Moderate User
For an entire door or the rubber strip towards the front top area?( i think the seperate top seal is called the secondary seal???) Door seals are butyl compound which is expensive. Suprised they would only be $20 a door? Especially the driverside where most people would need to replace after a few years of abuse. I figured they would bend everyone over on stuff like that. LOOK
Old Jan 31, 2010 | 01:55 PM
Albertaramfan's Avatar
Albertaramfan
I used to have this problem as well. Replaced the weatherstripping under warranty and that fixed it.
Old Jan 31, 2010 | 03:28 PM
dodg360's Avatar
dodg360
I mentioned mine to the dealer when I had it there for an oil change and they put "New and improved" seals in for free. They said there was a TSB about it. Mine's an 04, though, so I don't know if that would apply to yours as well or not. Worth asking.
Old Jan 31, 2010 | 04:32 PM
new2this's Avatar
new2this
i have the same problem but its both doors, at first i thought it was just wind noise over the sails we have for mirrors but when i pulled the top corner of my door in it would stop. i would love a way to fix the annoyance...
Old Jan 31, 2010 | 11:31 PM
chrisy1961's Avatar
chrisy1961
The upper or "secondary" seals get torn by the doors opening and closing due to a poor design. The replacement seals are redesigned so the door will not hit them. I changed mine in November and they were about $20 each from the dealer. Takes 5 minutes to replace. You can see the difference in the seals if you lay them side by side.
