Steering and shock noise
Old Feb 3, 2010 | 03:39 PM
hoss67's Avatar
hoss67
Originally Posted by cwboyjohnny24
I would check to make sure it's in proper place and that all the bushings/isolators are where they should be. If the spring isn't set properly in the bucket it'll make some noises on you.
How do u know if the spring is not in the right place?
Old Feb 3, 2010 | 03:53 PM
cwboyjohnny24's Avatar
cwboyjohnny24
on the bucket there's an indention where the end of the coil sits. Don't forget to check the isolator for the spring and your bushings for the top of the shock.
Old Feb 3, 2010 | 03:55 PM
hoss67's Avatar
hoss67
I am going to go attempt this in about an hour i will let you know how it goes and wat i notice just incase i missed something, Thanks
Old Feb 3, 2010 | 04:25 PM
cwboyjohnny24
sounds good, pm me if you need to incase the thread gets way down there. Take pictures if you need to also.
