Cummins Engine Swap, trying to make PCM understand changes
Old Jun 18, 2010 | 04:40 PM
  #61
Freakinkeith806's Avatar
Freakinkeith806
Thats like a dream come true!
Old Jun 18, 2010 | 05:04 PM
  #62
cheapbeater's Avatar
cheapbeater
well... hows she go???
Old Jun 18, 2010 | 06:15 PM
  #63
AF_HEMI's Avatar
AF_HEMI
screw the pics... i want VIDS!!!!!
Old Jun 18, 2010 | 06:29 PM
  #64
4XLgatorfan's Avatar
4XLgatorfan
WOW! What a mod! The truck looks great, you should be very proud of the accomplishment. Nice work.
Old Jun 19, 2010 | 03:40 AM
  #65
Chris Mallett's Avatar
Chris Mallett
Thanks for the compliments. He has not pushed on it real hard yet but my modded dually don't have anything for it. The only thing that has been modded on the 12ver has been fuel plate, AFC adjustments and timing at 16-17*. Hits a good lick.
FWIW Diesel World mag did take a few pictures and had him fill out the papers for publishing while in Ohio. Hope he gets a nice write up.
Old Jun 19, 2010 | 10:54 AM
  #66
oefootball_70's Avatar
oefootball_70
yeah, we deff need videos of the motor inside of that beast running. please
Old Jun 19, 2010 | 11:12 AM
  #67
BadHab1t's Avatar
BadHab1t
yeah man we need more....
Old Jul 5, 2010 | 10:25 PM
  #68
Chris Mallett
Started a new thread, a couple videos also. My camera operating stinks, but oh well.
https://dodgeforum.com/forum/3rd-gen...-like-oem.html
Old Mar 15, 2018 | 05:58 PM
  #69
njdevi11's Avatar
njdevi11
Originally Posted by Chris Mallett
Everything is working great, including the cruise control. The transmission woes had to be cured with a standalone controller. The secrets of the dash working have to remain that, but I will say the JTEC systems have to have a cam signal to start it all.
I'm going to bump this out of morbid curiosity, Does anybody know what needed to be done to fix the gauges? I'm assuming that his home made "cam sensor" wasn't setup with the correct tooth pattern. I'm not sure what the setup is on the 5.9 but my guess is that he didn't have the correct # of teeth, or the cam had a "missing tooth" pattern that could not be simulated on the crankshaft. I wonder if this would be easier with a 24 valve p pump. Or possibly putting a 24valve cam gear and sensor on the 12valve. My 24 valve p pump swap had wonky gauges until I got the cam sensor in just the right position.
Old Mar 15, 2018 | 08:14 PM
  #70
njdevi11's Avatar
njdevi11
I did some more snooping, I found this guy with a 5.9 gas with a scope on his crank position sensor (blue), cam position sensor (green) and coil (yellow). It looks like the crank signal is 16 pulses per rev, and the cam position sensor switches High/Low every 1/2 rotation. Hope this helps somebody. I might be tempted to do a swap like this someday.
Attached Thumbnails Cummins Engine Swap, trying to make PCM understand changes-99-dodge-ram-1500-5-2-with-a-bad-crank-sensor-youtube.png
