3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Can someone please tell me the heights (front and back) of a Ram 1500 with a 4" lift and 35" tires? I've got a leveling kit right now and 35's but I'm wondering how much more the 4" would give me.
Thanks!
You got a tape measure ??? Measure from the ground up 4" past the fender well.
Guess I wasn't clear, I'm wondering what the difference in height would be if I had a 4" lift instead of the leveling kit I have. My truck is not sitting at stock height right now.
Thanks!
I have a 4" Rancho suspension lift and 35" Cepek FCIIs which actually measure at 34 1/4". It's raining buckets right now, but if you can wait till tomorrow, I'll go outside and measure it for ya...
The level adds more than 2", I believe it was even you who posted the diagram of how the 2" block raises more than 2 inches. The level spacer up front should raise somewhere between 2.5 to 3 inches.
SHILO 2 DIFFERENT TRUCKS 1500 IFS and a 2500 sfa. on a 1500 IFS the max you are going to get is a 2" level ..on a 2500 SFA ski is the limit
Then how come the leveling kit I have in the mail is sposed to raise more than 2" in the front? I'm confused, and no I'm not trying to undermine you and be a smartass I'm genuinely lost after that reply.
That's EXACTLY what I'm looking for. Thanks so much!
Ok then add 2" from the ground to the fender .. Your levell kit gives you 2" so just add 2" to the set up to have now... There ya go..
I don't know much but I'm thinking that simply adding 2" over an unknown brand leveling kit is much too subjective. I've seen tons of half tons on 35's and leveling kits that sit at different heights than me.
Thanks!
