Sparkplugs
Old Feb 5, 2010 | 07:27 PM
  #21
jes2561's Avatar
jes2561
Allways gap ur plugs. Even pregapped plugs get banged up or done wrong , its best to check them. Champs are 045.
Old Feb 5, 2010 | 08:09 PM
  #22
ahook168's Avatar
ahook168
HAHA Weed. If you wanted to do it the "right" way then a spark plug socket works great. It was just a little tight getting to the back ones. The flexible hose was awesome and it was a good for the "feel" of it.
Old Feb 5, 2010 | 10:19 PM
  #23
weedahoe's Avatar
weedahoe
Hall of Fame Member
HA! I know the feeling but if you do a body lift then you will have more room back there. ::hint hint::
Old Feb 6, 2010 | 06:13 AM
  #24
Beastro's Avatar
Beastro
Yes I was looking at the back ones to day after work and i made up my mind going to get a body lift
Old Feb 6, 2010 | 08:01 PM
  #25
ahook168's Avatar
ahook168
Just put new champion copper plugs in the truck. runs way better than the bosch platinums.
Old Feb 6, 2010 | 09:23 PM
  #26
BEAR's Avatar
BEAR
Originally Posted by ahook168
Also, a 12 inch piece of fuel line works great for getting the old plugs out and the new ones in.
a old spark plug boot, if you have a old set of wires laying around, works great too.
Old Feb 27, 2010 | 02:49 AM
  #27
treston17's Avatar
treston17
Go with the OE Champions, they come pre-gapped at .045". As for platinums please do not do that to your engine, HEMI's are high compression engines not made for platinum plugs, they break down and gap widely at around 10K miles. I had a dealership mechanic tell me they had a HEMI come in where someone put platinums in it and were racing the truck at the local strip. Engine was making a terrible noise after they took it apart they found the tip of one of the platinum plugs broken off and welded to the inside cylinder wall. Platinums can't handle the higher temperature of high compression engines. They work fine for going the speed limit on cruise control but if your hot roding the gas pedal or towing anything larger than a canoe don't risk it. The engineers spent years deciding what the best spark plug was for the HEMI thats why they recommend it, don't listen to some over night mechanic who thinks more expensive parts equals more horsepower...However Iridium plugs work just as good and only need replacement at 50K-60K rather than 30K but at $6 a plug for 16 of them I would stick with the champions, I bought 16 of them at NAPA for $1.59 a pop yesterday
Old Feb 27, 2010 | 04:39 AM
  #28
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by 04HemiGreg
Problem is, we have 1 store here - Advance Auto. That's so typical for this hole in the ground I live in. So, all that stuff is on my list for the next time I hit the "big city".
lol, Where I live downtown is the Advance Auto store...
Old Feb 27, 2010 | 05:11 AM
  #29
Marx's Avatar
Marx
Originally Posted by cwboyjohnny24
Yep, it's .045 on the hemi and magnum motor.
hemi and magnum are the same motor
Old Feb 27, 2010 | 10:32 AM
  #30
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by weedahoe
When you get your plugs just check them at the store or buy another tool for $1
ughh, I hate those cheap things. The WIRE gapper is the ONLY tool i would ever use on my plugs. I suppose a little difference from one plug to the next won't make a big difference right away, but as they wear down they will.
FYI. I gapped all of my plugs for my mustang one time using the half dollar tool(slider type) and then checked with the wire gapping tool ($5) 3 of the plugs were .02" off, 1 was .04" off, and 2 more were .01" off.
That's 6 out of 8 that were wrong and you guys are installing 16 of them. I know .02 doesn't seem like much but, .047" compared to .045" is more than I'd like, especially when getting upwards of .04 diff.
Those are a good general checker, but they are just too cheap for me. Inconsistent i suppose is the proper wording.
