Come in if you have halo fogs!
Old Feb 5, 2010 | 07:27 PM
iownan05's Avatar
iownan05
Default Come in if you have halo fogs!
So today I got my fog/halo lights set up and i can get the fog light to come on no problem. But for some reason the halo doesn't come on? I have two switches for on and off and it just works with the fog light. What can I do to just have the halo on?
Old Feb 5, 2010 | 08:15 PM
John  M's Avatar
John M
The halos should have separate wiring. Most people connect the halo's + wire to the parking light which is the center wire in the parking light plug on each side of the truck.
Old Feb 5, 2010 | 08:42 PM
irelandshemi's Avatar
irelandshemi
i ran my halo wired through the fire wall, and then to my switch, then i spliced into the radio for power, that way if i accidentally leave the switch on they will shut off with the car anyways, are you sure all your wiring is good? i know at first only one of mine would light up and found out the wire came loose somewhere down the line
Old Feb 5, 2010 | 08:58 PM
sharkhunter10's Avatar
sharkhunter10
ya check your wiring i had to do mine like ten times to get mine right
Old Feb 5, 2010 | 09:38 PM
iownan05's Avatar
iownan05
well i figured out that the right switch works for the fogs and the left one works for the halo's... ive got the fog light down correctly i just have to switch a few things around to the the halos working correctly.
Old Feb 5, 2010 | 10:44 PM
irelandshemi
glad to hear you got it figured out, what kind of lights did you get
Old Feb 5, 2010 | 11:02 PM
iownan05's Avatar
iownan05
http://www.slickcar.com/productdetai...ProductID=6604
these exact ones but I got mine off ebay for just under 80
Old Feb 5, 2010 | 11:22 PM
irelandshemi
pretty much the same ones i have, im sure its been posted (and sorry to hijack the thread) but anyone have any ideas what the bulb size these are i wanna do hid in mine
Old Feb 6, 2010 | 03:35 AM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
If its the same as the mopar ones, they're 9006's I do believe.
