My weekend project finished!
Old Feb 10, 2010 | 09:34 PM
  #21
TRXHemi's Avatar
TRXHemi
I like the AirRaid but could not find it for less than $100. I put this one together for about $45 or so. The HID kit I bought from HIDextra.com for $60 shipped after the $15 off coupon code. They are 8000K and look pretty good at night. I like them. I plan on doing the heads eventually.
I would like to eventually do the Hellas in HID as well, but you have to modify the casing for the Hella 500 because of the depth. The Hella 700s are a little deeper and a little larger than the 500s. But that will come!
Old Feb 10, 2010 | 11:17 PM
  #22
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
Everything looks good buddy! I did my intake the same way, but yours looks a little bit classier. I used regular ol plumbing couplers, 4-3.5in Then painted the tube black to match the couplers, doesnt look too bad, but could probably be better.
One problem I did have, I couldn't get the stock box to sit back on the studs as it was factory. So, to compensate, I just cut the intake tube on the box back a couple inches, so it was still right in front of the airflow. 'Rigging at its finest, lol. I had a loud whistle for a while, but that seems to have gone away.....
Edit: Heres a pic before it was painted. It looks much better now. I think my "fitment" problem is with the huge elbow. IDK, after looking at this pic, Im kinda embarrased about it, lol. I still have about.....9ft of this pipe left, might have to try something else....
Old Feb 11, 2010 | 10:34 AM
  #23
jose13b's Avatar
jose13b
HIDextra.com
nice thanks headlights are 9007 and fogs are 9006 right and you said yours are 8000k how did you get the coupon
Old Feb 11, 2010 | 12:47 PM
  #24
oefootball_70's Avatar
oefootball_70
DDM is 29 dollars. Thats what I have.
Old Feb 11, 2010 | 09:25 PM
  #25
TRXHemi's Avatar
TRXHemi
DDM - $29? Wow!! I found the HIDextra coupon code on here somewhere. You may have to search for it. I think I may do the slim fit ones next from HIDextra. I will check out DDM as well. Does anyone have that site? Wait....
www.ddmtuning.com
Old Feb 11, 2010 | 09:37 PM
  #26
4matty3's Avatar
4matty3
do you have a write up on how to put the hids in the hellas? or anything to follow
Old Feb 11, 2010 | 10:02 PM
  #27
TRXHemi's Avatar
TRXHemi
I heard that the DDM products do not work with our Chrylser products....anyone?? Or at least the new Dodge RAMs - '06 and up...
I have not done the HIDs in the Hellas as of yet. When the time comes, I will definitely post some pics. I wonder if anyone has done that yet??? I know you have to modify the housings as they are a little slim.
Rome was not built in a day. It will come!
Old Feb 11, 2010 | 10:20 PM
  #28
4matty3's Avatar
4matty3
theres a bunch of post in Dodge Talk about ddm kits. also the hids in the hellas. im just trying to figure out how hard it would be, since im not good at wiring
Old Feb 12, 2010 | 08:50 PM
  #29
jose13b's Avatar
jose13b
wiring is easy you can buy a relay kit anywhere if you need a diagram I got your back
