Level kit install pics
Old Feb 6, 2010 | 04:30 PM
Matt99's Avatar
Matt99
yup, ive had that problem a few times...you are just going to have to get a sawzall and cut it off. I dont know why they dont have a better way to grip the top of that shock, its not even a hex head, two sides are flat and the other two round
Old Feb 6, 2010 | 04:50 PM
BadHab1t's Avatar
BadHab1t
pics wheres the pics?....j/k hope your having better luck...
Old Feb 6, 2010 | 05:17 PM
dmull013's Avatar
dmull013
Yeah I hope you are having better luck too. I hope mine isint like this when i get around to doing it.
Old Feb 6, 2010 | 05:19 PM
Blk05HEMI's Avatar
Blk05HEMI
Hope you get it done man!! Cant wait for some pics!!!
ZW
Old Feb 6, 2010 | 06:12 PM
Shiloh 24's Avatar
Shiloh 24
I got the spring partially in but I'm curious, do I have to line up the end of the coil on the bottom with the hole for it in the lower control arm?
Old Feb 6, 2010 | 06:43 PM
cwboyjohnny24's Avatar
cwboyjohnny24
There should be an indention in the lower coil bucket that matches up with the spring. It should only if I remember correctly the indention should be only a few inches. That's where the end goes. Make sure you get that spring seated right or you're gonna have squeaking.
Old Feb 6, 2010 | 09:22 PM
Desert_Ram's Avatar
Desert_Ram
what level kit did you get?
Old Feb 6, 2010 | 11:06 PM
Shiloh 24's Avatar
Shiloh 24
Got the 2" coil spacers from Fat Bob's Garage with Pro Comp ES3000 shocks. I got the kit on but I think something's effed up. It drives and rides like total dog chit and the front is higher than the rear. I'll get pics up in the morning it's dark and I just wanna sleep, I've been at it since 10 this morning.
Old Feb 6, 2010 | 11:08 PM
Freakinkeith806's Avatar
Freakinkeith806
I have the same kit on mine with no probs
Old Feb 6, 2010 | 11:12 PM
Shiloh 24's Avatar
Shiloh 24
I may be wrong but it appears to me that at full extension of the suspension the upper control arm is hitting the top of the shock tower. I'm picky as hell though and I can tell the slightest little differences when driving my truck so it may just need and alignment really really bad.
edit: heres some during pics and that damn shock mount I had to cut off.
