Level kit install pics
Old Feb 6, 2010 | 11:52 AM
Shiloh 24's Avatar
Shiloh 24
Default Level kit install pics
I'm in the process of putting in my leveling kit but I can't figure out how to get the shock mounting bracket to fit through the bushing. Heres a pic any help would be appreciated.
Old Feb 6, 2010 | 12:20 PM
Myosinner's Avatar
Myosinner
Maybe Im just dumb but what the heck is that thing?
Old Feb 6, 2010 | 01:22 PM
cheapbeater's Avatar
cheapbeater
lube it up and slide it in. you might have to give it a good ramming... you know how to do that right?
haha. when i put my roughcountry shocks on the shafts were a bich to get through the bushing. put a little motor oil or silicone spray on them and they should go in...
edit: you are trying to get that metal piece through the rubber bushing in the shock right?
Old Feb 6, 2010 | 01:34 PM
Shiloh 24's Avatar
Shiloh 24
Well I solved that dilema, I took it to my local auto parts store and they popped out the bushings and used WD40 to put in the bushing and they used some kind of press to put the bushing back in the shock took em like 30 seconds. Now I'm having trouble getting the damn caliper off!
Old Feb 6, 2010 | 02:17 PM
Matt99's Avatar
Matt99
haha yea that caliper is a bitch sometimes....i actually had to pry it off one time and it took me like 20 min...remember about using pry bar, works alot better for the spring
tuned93's Avatar
tuned93
PB Blaster...
Old Feb 6, 2010 | 02:32 PM
Freakinkeith806's Avatar
Freakinkeith806
A little elbow grease worked for me, and a hammer lol
Old Feb 6, 2010 | 03:30 PM
Shiloh 24's Avatar
Shiloh 24
Got one caliper off about to start on the other side, now the freakin stock shocks are being a bich and don't wanna come off. The top bolt won't loosen, I've sprayed it with WD40 used vice grips and it just keeps spinning free. I'm about to just take the cutting wheel to it.
Old Feb 6, 2010 | 03:36 PM
SMKNRAM's Avatar
SMKNRAM
not a good idea! have you got the nut off?
Old Feb 6, 2010 | 03:52 PM
Shiloh 24's Avatar
Shiloh 24
The nut on top of the shock won't come off and the little hex head at the top were you hold to keep the shock from spinning is completely rounded off and turning.
