Sirius install - constant 12V vs switched 12V
Sounds like I lucked out then in my '06 when doing the deck install by getting accessory power from the cig lighter!
Now for tying into constant... I should be able to do it off the other accessory outlet which is constant instead of going behind the deck into the harness right? (just a little easier since the wires from the Sirius are right there already and I won't have to pull the deck out again and try to fit all those cables in there again)
Thanks again for your post! Nice to know how that module works now!
sorry AlbertaRAM i was under the impression that the sirius module needed both constant and ignition. I have never installed one, but i thought it needed both power sources.
If I were you while you have your dash apart, it might be an idea just to run a seperate #14-or even #12 from the battery to a distribution block. Or better yet a fuse block. That way if you decide you want to add anything else in, like a GPS or a 110V power inverter. You can get your 12V Constant right from that fuse block. It will be fused power, and will not cause any wire damage or anything to the wires your are splicing into, not to mention you might go through fuses, depending on where you hook it in. Im not sure how many amps that Sirius module uses, but its always better to be safe then sorry.
Maybe its just the electrician in me talking, but thats what i would do, in fact thats what i am doing once my radar detector comes in. You can put all your electronics unto each of their own fuses, and not have to worry about loosing a cig lighter fuse and other things you might tie into because that certain electronic took too much power.
You also have part of your dash ripped apart now, so i might be a little less work!
