Broken Valve
Old Feb 9, 2010 | 09:52 PM
ried69's Avatar
ried69
Default Broken Valve
Has anyone else here had a valve bend/break/stick on their Hemi engine? I've been battling with my truck all week, and we've finally discovered that I have an intake valve not sealing up at all. I've heard said that the Hemi's have had problems with breaking springs/various other problems like this. If anyone else has had this, let me know if it has happened and what all was wrong. Thanks.
Old Feb 9, 2010 | 10:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
several guys with 03s have broken springs. There are more than a few threads on this
Old Feb 9, 2010 | 10:43 PM
HammerZ71's Avatar
HammerZ71
yep, broken springs seem to be fairly common with the '03s. Ain't heard of anyone with an '04 up have one, except for one guy I know with an '04 who did a Comp 260 Cam with the stock springs...
Old Feb 9, 2010 | 10:55 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
http://www.dodge talk.com/forums/showthread.php?t=287913
Old Feb 10, 2010 | 11:13 AM
ried69's Avatar
ried69
My valve spring is just fine, that didn't break. It's my actual valve. I wish it was just a spring though, that would be much easier to replace.
Old Feb 10, 2010 | 12:50 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive never seen a valve bend or break without something else failing first and then causing the valve to bend or break
Old Feb 10, 2010 | 01:03 PM
HammerZ71's Avatar
HammerZ71
Everyone and I mean everyone with cylinder problems that I know of has been running 87 octane regularly. Now just so's I can update my little database, and be honest, have you been running 87 octane?
Old Feb 10, 2010 | 02:45 PM
new2this's Avatar
new2this
I have, but ive got an 02 4.7 Should i be running something else in fear of busting something up inside my engine?
Old Feb 10, 2010 | 06:42 PM
lxman1's Avatar
lxman1
Site Moderator
No, just the Hemi really needs 89 octane per the owners manual.
Sounds like you need to give a call to www.inertiamotorsports.com and get a nice set of their heads!!
Old Feb 10, 2010 | 08:38 PM
ried69's Avatar
ried69
I run 91 in my truck, with the Tow tune, and I know to never put 87 in my truck.
I have no 100% assurance that my valve is bent, but it definitely is not sealing, and causing a leak. The spring isn't broken, but it does have some give in it.
