Knock/Thump sound- Not The Engine
Old Feb 11, 2010 | 12:44 PM
05hemi05's Avatar
05hemi05
Default Knock/Thump sound- Not The Engine
I have an '05 QC hemi with about 65000 miles on it. Lately ive noticed that if i take a turn or go over a bump while turning i hear a knock/thump sound coming from the front wheel area. Its hard to say exactly where its coming from but i know its not the engine...
Does anyone have any ideas about what this could be? Or at least tell me where i should start checking?
I just bought this truck a few weeks ago, i hope its nothing major
Old Feb 11, 2010 | 12:55 PM
cwboyjohnny24's Avatar
cwboyjohnny24
I would start by looking at your upper and lower ball joints. Then move to the tie rod ends and check them out too. I'm assuming you have a 2wd?
Old Feb 11, 2010 | 01:28 PM
05hemi05's Avatar
05hemi05
yeah sorry its 2wd. I gotta go to work but ill check back later and give some more details about where the sound is coming from if i hear it again while driving around today.
thanks for any help guys
Old Feb 12, 2010 | 12:15 AM
05hemi05's Avatar
05hemi05
So after drivin around today i realized that it only thumps when i take a turn AND hit a bump. It doesnt make any nosie when i just turn on a flat surface.
Any ideas about what this could be?
Old Feb 12, 2010 | 09:07 AM
cwboyjohnny24
If it doesn't make the noise when you're driving straight and hitting a bump I would imaging I would start looking at the tie rod ends, then think about the ball joints.
Old Feb 12, 2010 | 09:14 AM
05hemi05's Avatar
05hemi05
no it doesnt, just when turning and hitting a bump at the same time, ill check out the tie rod ends this weekend and see whats up
thanks
Old Feb 12, 2010 | 09:27 AM
RedTruck-VA's Avatar
RedTruck-VA
Sounds like you are talking ball joints. Lift the wheel off the ground a few inches and use a bar under the tire to see if you can move anything.
Old Feb 12, 2010 | 09:48 AM
05hemi05's Avatar
05hemi05
newb question for ya, what would this do? would it tell me if the ball joints were bad?
Old Feb 12, 2010 | 09:52 AM
RedTruck-VA
Default Ball Joints
Yes, if you can move them they are bad.
Old Feb 12, 2010 | 09:54 AM
05hemi05's Avatar
05hemi05
good stuff, ill check it out this weekend, thanks for the help!
