Level update and info about fatbob's kits
Old Feb 12, 2010 | 02:16 PM
  #31
Shiloh 24's Avatar
Shiloh 24
Originally Posted by 98cherryram
That 2wd stance always just seems so short to me... I dont know, I guess its because Ive only ever driven 4wd trucks, you should do a spindle shiloh and a shackle in the rear, or at least a block... I think it would be nice to see your truck sitting at like a 4wd leveled stance instead of a 2wd leveled stance...
I might do that eventually, if I did 4" spindles and my 2" coil spacer technically that would be a 6" suspension lift (with block in back of course). I think I'll wait on that though cuz I'm thinkin I wanna do a 3" bl next year or right before I get new tires the next time.
Old Feb 12, 2010 | 02:19 PM
  #32
98cherryram's Avatar
98cherryram
I think you should do the suspension lift first, they just look cleaner imo, I'm not even going to do a BL, Im just going to put a 6 inch kit on mine and call it good there.
Old Feb 14, 2010 | 09:59 PM
  #33
oefootball_70's Avatar
oefootball_70
look how much space I have
I could prob add a 2.5 inch spacer.
Old Feb 14, 2010 | 10:02 PM
  #34
Shiloh 24's Avatar
Shiloh 24
You got the 6" Rough Country lift don't ya OE? Does that consist of spindles and coils, and then blocks in the rear?
Old Feb 14, 2010 | 11:37 PM
  #35
hemiguy0302's Avatar
hemiguy0302
Is you sway bar disconnected? If so how in the hell does the thing not tip over in a corner mine with worn bushings felt like it could easily flop on its side.
Old Feb 15, 2010 | 12:09 AM
  #36
Shiloh 24's Avatar
Shiloh 24
Nice catch, that thing sure isn't.
Old Feb 15, 2010 | 08:51 AM
  #37
oefootball_70
Yeah I break those sway bar links like they are going out of style. I am prob going to fab up the Kore ones here before too long
Old Feb 15, 2010 | 08:52 AM
  #38
oefootball_70
Front: New 6" coil springs, front and rear crossmembers, driver and passenger side knuckles, front sway-bar relocation brackets, and front sway-bar links.
Rear: 3" block and u-bolt kit.
Old Feb 15, 2010 | 11:08 AM
  #39
Shiloh 24's Avatar
Shiloh 24
In theory you could add another inch or two in there then. All you would have to do it find the longer shocks to make up for it, and you would have to get bigger blocks in the rear.
Old Feb 15, 2010 | 01:16 PM
  #40
oefootball_70
2.5 inch spacer, and 2 inch add a leaf.
But then I would need bigger tires, and with bigger tires I look like a huge 4x4. And I don't like getting stuck in a little snow looking like that.
You know?
