Help with level kit/Coil Spring Spacers
Old Feb 12, 2010 | 05:50 PM
adavison's Avatar
adavison
Default Help with level kit/Coil Spring Spacers
Hey, so i just bought 2" coil spring spacers..leveling kit. I read on the internet that i need to rent some tool to release the pressure from the APS Valve ( Air Pressure Sensor Valve ). Im just wondering if this is 100 percent true, and if so, is there any way that i can work around this with-out renting the tool to release the pressure ? I have a 2002 Dodge Ram 1500 2WD.
Old Feb 12, 2010 | 06:43 PM
cwboyjohnny24's Avatar
cwboyjohnny24
I did my 2wd and I don't have an air pressure sensor valve anywhere near the suspension. Where is this located on your truck? I haven't heard of this before.
Old Feb 12, 2010 | 06:45 PM
cwboyjohnny24
Is this for your tires? To tell you when your air pressure is low?
Old Feb 12, 2010 | 07:03 PM
adavison's Avatar
adavison
Well actually my friend looked up on the net about installing the level kit for my truck and i guess he came across something to do with a air pressure sensor valve on the shock or something ??
Old Feb 12, 2010 | 07:10 PM
cwboyjohnny24
I highly doubt you have air shocks on your truck unless you've put them on.
Old Feb 12, 2010 | 07:17 PM
adavison's Avatar
adavison
I'm not sure. I bought the truck a couple months ago. When i bought it, it already had cold air-intake and exhaust system on it...so it might ?
Old Feb 12, 2010 | 07:30 PM
cwboyjohnny24
I don't think you had a factory option on the truck for air shocks. Look at the shock and see if there's an airline coming off of it. There should be a line where you can add or remove air, kinda like the valve on a tire. Unless you have an on board air compressor?
Old Feb 12, 2010 | 07:33 PM
ramhunter9's Avatar
ramhunter9
its your tire air gauge shouldnt matter none .
Old Feb 12, 2010 | 07:42 PM
meen green machine's Avatar
meen green machine
did you order this kit off ebay.
Old Feb 12, 2010 | 07:45 PM
adavison's Avatar
adavison
Not yet..im going to. Why ?
