Any ideas about what this could be?
Old Feb 13, 2010 | 10:52 PM
JoeHemi's Avatar
JoeHemi
I know youtube has some good vids on what a bad u joint looks like. Good thing is they're pretty easy to replace if thats the problem
Old Feb 13, 2010 | 10:58 PM
RedTruck-VA's Avatar
RedTruck-VA
I haven't seen the video's but you can jack up the rear and look for play in the joints or if there is red (rust) dust on the joints it is a good indication that they are bad.
good luck..
Old Feb 13, 2010 | 11:11 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like a broken belt in a tire to me.
Old Feb 13, 2010 | 11:13 PM
05hemi05's Avatar
05hemi05
Ive never heard of that, is there any way to check for it? If the u joint is fine ill look at this next
Old Feb 13, 2010 | 11:38 PM
RedTruck-VA
Bulge on the tire is a broken cord. Usually at slow speed in a smooth parking lot the vehicle will crab walk side to side.
Old Feb 14, 2010 | 12:11 AM
lxman1's Avatar
lxman1
Site Moderator
You can jack it up and spin the wheels. You will see one that is out of round fairly easy. Usually a broken belt will be the cause.. And yes, you will usually feel it have a bit od a wobble at slow/idle speeds as well. Shoot, you might also make sure all of the lugnuts are tight since you just bought the thing.
