Re-Wired the Lights
Old Feb 14, 2010 | 02:23 PM
TRXHemi's Avatar
TRXHemi
Default Re-Wired the Lights
Last weekend I added a second pair of Hellas behind the grill. I went ahead and did two new heavy duty relays, as well as 14 gauge wire for the whole setup. I also added a second switch so each pair could operate independently.
The first switch I had was mounted by itself. When I added the second switch, I turned them both sideways. I had to trim a little bit out for them to fit.
The new relays.....
Old Feb 14, 2010 | 02:33 PM
JoeHemi's Avatar
JoeHemi
Lookin good. Whered you get the switches from?
jose13b's Avatar
jose13b
looks good make sure you tape up the relay
Old Feb 14, 2010 | 02:42 PM
TRXHemi's Avatar
TRXHemi
Yep, I am not quite done strapping up the wiring yet. They sit at the top and the very back of the engine compartment. They should be good. I need to get some electrician's tape.
Old Feb 14, 2010 | 03:03 PM
sharkhunter10's Avatar
sharkhunter10
nice man looks good!
Old Feb 14, 2010 | 03:07 PM
jose13b's Avatar
jose13b
when someone cuts you off turn them on and get a train horn
Old Feb 14, 2010 | 06:29 PM
TRXHemi's Avatar
TRXHemi
http://www.otrattw.com/products.php?cat=17
This is where I bought the switches. They have several different ones to choose from. You know, I was thinking.......I have an extra set of lights. I may mount them on the bumper on each side of the hitch. They sell a switch that says "backup lights".
Old Feb 15, 2010 | 02:43 PM
Senomar_DTK's Avatar
Senomar_DTK
I also want to add two more Hellas and upgrade my wires and relay. What size relays did you use to handle this? Also I wanna put in 100 watt bulbs so would that size wire and relay be safe to handle the more power?
And how do you upgrade the wires that have the in line fuse in them? I wouldn't know how to handle that one.
Old Feb 16, 2010 | 07:20 PM
jose13b's Avatar
jose13b
30 amp relays just buy a relay kit with harness for fog lights look in autozone or pepboys
Old Feb 16, 2010 | 08:50 PM
TRXHemi's Avatar
TRXHemi
I did 40 amp relays. I also bought heavy duty in line fuse holders. See the pic......
I used a 20 amp fuse for each.
