Weird behavior in burnout
Old Feb 15, 2010 | 11:35 PM
rickof08's Avatar
rickof08
Default Weird behavior in burnout
So i recently put a detriot truetrac w/4.56 gears in my truck. Earlier today I decided to do a burnout at a stop sign. both tires started spinning BUT my *** end started hoping up and down real bad. Why is it doing this and what can i do to stop it?
Old Feb 15, 2010 | 11:41 PM
DodgeThunder's Avatar
DodgeThunder
Sounds like axle hop, no weight over the rear end and ****ty tires?? My brothers truck used to do it to from a stop light if he hammered on it.. Im not sure what exactly causes it but ladder bars will fix it..
Old Feb 15, 2010 | 11:44 PM
rickof08's Avatar
rickof08
the tires are fairly new. they are Aurora RH08 275/55/20 which i think is owned by hankook. When you say ladder bars is that the same as traction bars or caltracs?
Old Feb 15, 2010 | 11:52 PM
AF_HEMI's Avatar
AF_HEMI
its actually called axle wrap, which produces axle/wheel hop. basically there is so much torque being put on the axle, it actually twists. it'll twist a bit, then snap back straight, then twist, over and over again very quickly, causing the axle/wheels to actually bounce.
Ladder bars are just a brace that connects the axle to the frame (parallel to the frame) to prevent the axle from twisting.
Old Feb 15, 2010 | 11:56 PM
rickof08's Avatar
rickof08
yay more money to spend......lol oh well
Old Feb 16, 2010 | 12:00 AM
dirtydog's Avatar
dirtydog
Moderate User
well said AF!
Old Feb 16, 2010 | 12:17 AM
Matt99's Avatar
Matt99
dog, your sig is making me feel like im epileptic and in shock
Old Mar 7, 2010 | 04:43 AM
JoeHemi's Avatar
JoeHemi
haha
Old Mar 7, 2010 | 05:08 AM
RedTruck-VA's Avatar
RedTruck-VA
Yep, Spring wrap or axle wrap. Caltrac time..... $500 should cover it.
Old Mar 7, 2010 | 05:18 AM
Martin460's Avatar
Martin460
http://www.4x4wire.com/jeep/tech/susp/axlewrap/soa4.gif
