areo 3030xl
Old Feb 20, 2010 | 05:40 PM
m_durham_226's Avatar
m_durham_226
Default areo 3030xl
Question is I am going to be putting one on here in the next week with the exit right before the rear tire with no stock resinator is there any kinda of advice or tips you guys could give me for this istall or pics would be great too thanks in advance
Old Feb 20, 2010 | 06:20 PM
OklaHemi's Avatar
OklaHemi
no advice or tips but you will love it.
Old Feb 20, 2010 | 07:02 PM
dr650rider's Avatar
dr650rider
Are you going to add the 3040 tip? It gives it a nice touch. It would probably look really good with your exit point too. As for the AT3030XL, you'll love the low rumble at idle, the strong roar with throttle, and the pop and crackle on deceleration.
Old Feb 20, 2010 | 10:31 PM
m_durham_226
Not sure what tips I am going to go with but I did find the areo tips for pretty cheap about $20 or $30....
Would there be a way of using part of the stock pipe and tip ??
Would that be able to be cut off and welded into the outlet of the muffler since it already has a nice bend to it already and I wouldn't need too much since it going to be coming right off the muffler to the side in front of the rear tire?
Old Feb 21, 2010 | 12:12 AM
mpk4580's Avatar
mpk4580
Default here is my install with AT3030
I used a 3" tailpipe extentsion and 3" clamps to install mine. Are you doin it yourself ? sorry about the salt all over the exhaust, this is new england... Good luck no matter how you do it you will love the rumble when you start it up as well as WOT.
Old Feb 21, 2010 | 12:30 AM
m_durham_226
I was going to have a guy I work with help me cause he has a welder and all the necessary tools do to the work...So you used the extension after the muffler...?? Would it be the same as the cutting the stock one off after the resinator cause I a chrome tip on there now and looks to have the right bend... It will soon be replaced with the aero tip that I found pretty cheap (a lot cheaper than what they sell it for)...
Old Feb 21, 2010 | 12:32 AM
mike_r's Avatar
mike_r
I would clam it over weld it. If you ever decide to sell the truck, or for some reason you don't like it, it will be a while lot easier to change if you clamp it.
Old Feb 21, 2010 | 02:00 AM
m_durham_226
when you clamp it....I know this may sound stupid but I know that I need a 3"in/3"out for the muffler and when I cut the old muffler off does the new one just slide right on or is there something else that I need to make it fit?
Old Feb 21, 2010 | 02:32 AM
m_durham_226
This is what I would need to put the muffler on myself...??
A pipe adapter that goes from a 3 1/2" to fit into a 3" and clamps, correct me if I am wrong..
Old Feb 21, 2010 | 03:22 PM
mpk4580's Avatar
mpk4580
Default Don't Cut it
Just unbolt the stock muffler. The stock one is 38.5" long band clamp to band clamp. The AT3030 was 20" long so after the AT3030 I put a 18" long extension to the stock tailpipe and resonator . There are hanger clamps for 2" exhausts that i used I just hammered the top part so that the hole would line up with a 3" U clamp, I did this twice. The whole thing was pretty simple it only took about and hour to remove the old one and install the new one.
