3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Brother in law has 08 ram withe remote start. Truck was working fine went into store hit unlock and it worked. He tryed to start and nothing, security light on radio works but it won't turn over. Any help would be great.
Told him to disconnect the battery and wait 5 min. and then try to start. It worked so he will just take it to the dealer and let them see if there is any problems.
another member had a similar issue. i told him to use his other key and he went out and it worked. Then all the sudden his other key worked after that. Could be similar problem. maybe you just need to reflash the ecu or the keys??
