truck is vibrating,why?
I use in the gas tank once it is almost empty after an oil change (cleans injectors). You can use it in the throttle body but it will smoke like a banshee. If you add it to the crankcase, make sure you put less oil to compensate for the extra fluid. Too much oil can be as bad as too little oil,
FF
FF
