rotors
Old Feb 21, 2010 | 06:19 PM
Roll.Tide's Avatar
Roll.Tide
New Member
Default rotors
I have 30,000 mile on my truck and the rotors are warped I under stand a lot of you guys had had the problem. I did not think they should have warped this quick but what do you guys thing of aftermarket crossdrilled rotors. Thanks for any help
Ron
Old Feb 21, 2010 | 10:59 PM
PVHF_Richard's Avatar
PVHF_Richard
How badly are they warped? can you actually see the warpage and does the ride quality change with warped rotors, cause my truck vibrates between 45 and 55 and the warped rotors make sense
Old Feb 21, 2010 | 11:02 PM
chambers's Avatar
chambers
I know some people have problems w/ them, I think I read that one cause was the wheel lugs being torqued too much. Try asking the guys in the 3rd gen section b/c you'll probably get more hits from people who have had this problem.
You probably need to have your tires balanced. Warped rotors should only cause vibration when you're braking.
Old Feb 21, 2010 | 11:38 PM
Roll.Tide's Avatar
Roll.Tide
New Member
yes they are warped, this only happens when braking
Old Feb 21, 2010 | 11:55 PM
chambers's Avatar
chambers
07 w/ 30k on it and that's not under warranty?
Old Jun 24, 2011 | 05:24 PM
HemiHound's Avatar
HemiHound
Angry 04 Dodge Ram 1500
I just put new rotors and pads on mine and it still vibrates when braking.What else could be wrong
Old Jun 24, 2011 | 08:08 PM
HammerZ71's Avatar
HammerZ71
Calipers...
Old Jun 25, 2011 | 04:48 PM
HemiHound's Avatar
HemiHound
Default Calipers
Is there some way to test the calipers or do i just have to buy and hope? Any info appreciated
Old Jun 25, 2011 | 09:32 PM
JPlaisted's Avatar
JPlaisted
My 02 has already gone through a set of rotors on the rear, and now the ones on the front are gone..so I ordered a new set of EBC Ultimax Slotted Rotors, and a new set of EBC Green Stuff Brake Pads. I hope this takes care of the problem...if it does, then I will buy another set for the rear..truck only has 96,000 miles on it..
Old Jun 26, 2011 | 01:36 PM
HemiHound's Avatar
HemiHound
Question Rotors
Why does Dodge have so much trouble with brake parts?I have a 94 Chevy truck and brakes is no biggy on it.What did engineers do wrong?
