Please help Dodge Ram Electrical Problem
Old Feb 23, 2010 | 02:41 PM
cmharcou's Avatar
cmharcou
Default Please help Dodge Ram Electrical Problem
My Dodge seems to have a mind of its own. Today I noticed that my left headlight was out. When I turned on my bright lights my right headlight went out but my left headlight came back on. Both turns signals are blinking fast either left or right. The "lamp out" dummy light is on. If I hit the brakes only the right rear brake light works. Any suggestions? A fuse or just a light bulb somewhere? Its a 2003 Dodge 2500 5.9 Liter Cummins Turbo.
Dead stuff:
- Only the right rear turn signal lamp flashes, and it's at a high speed
- 4-ways only illuminate the same right rear lamp, same high speed
- only 1 right rear brake light works
- right front low beam works but high doesn't
- left front high beam works, but low doesn't
Old Feb 23, 2010 | 02:51 PM
SMKNRAM's Avatar
SMKNRAM
whoa dude sounds like you need to be sharing that stuff with the rest of us!!
I think you are having a ecu issue!
Old Feb 23, 2010 | 03:08 PM
cwboyjohnny24's Avatar
cwboyjohnny24
There was a few threads a while back about people having problems like that. I believe the solution they ended up with was they had moisture/corrosion in the fuse box I think. A couple of 'em ended up replacing them and the problem was no more. Other than that I couldn't really tell ya.
Old Feb 23, 2010 | 03:18 PM
BadHab1t's Avatar
BadHab1t
i wonder if the rest of us could remidy this by placing a paper towel or those silica packs in our that way it doesn't happen to us....thats a damn shame i can only imagine what thats gonna cost...
Old Feb 23, 2010 | 03:25 PM
cwboyjohnny24
https://dodgeforum.com/forum/3rd-gen...nd-module.html
https://dodgeforum.com/forum/3rd-gen...eadlights.html
Check out these couple of threads. This sounds EXACTLY like the problems you seem to be having.
Old Feb 23, 2010 | 03:28 PM
cmharcou's Avatar
cmharcou
Thanks Cowboy JOhnny that is exactly what mine is doing. I have been searching these threads for 2 hours!
Old Feb 23, 2010 | 03:36 PM
cwboyjohnny24
hahaha. I just knew I had seen it before. No problem man. I hope you're able to clean it and not have to replace it. But with that said atleast you know where you stand bud.
Old Feb 23, 2010 | 05:48 PM
cmharcou's Avatar
cmharcou
I just ordered the part for the power distribution center *PDC* or fuse block. From what I am reading this is a common problem on early 03 2500's. Dealer is charging $425 for this part.
WWW.MOPARONLINEPARTS.COM
Part number Part Description Quantity Price Total
68005474AA BLOCK NONE 1 $261.80 $261.80
Sub Total $281.78
This was an updated part with an extra bottom housing to cover the electrical connections and bottom of PDC to protect from future water damage.
Part number on the part was 56049019AF but with housing changed to 6800544AA
Old Feb 23, 2010 | 06:35 PM
cwboyjohnny24
Good to know you got it figured out and did research man. Good luck and that's excellent information for other people who may be having the same problem.
Old Feb 23, 2010 | 06:42 PM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
Good to hear you got it figured out buddy. These guys on here are the **** aint they?
Is that a possiblity Jay, Jon, anyone, that we could silicone the fuse blocks to prevent any of this? If so, would that hinder any future uses of say, empty spaces in the fuse block? Just curious, all of a sudden Im all about preventative maintaince, haha.
