2002 ram headlights
Old Aug 23, 2009 | 08:59 AM
corey600's Avatar
corey600
Default 2002 ram headlights
I have a 02 1500 4x4. The low beam whent out on the drivers side headlight. so i changed out the bulb still no low beam. So far i have changed the malti-function switch and the headlight switch still have high beam and no low beam out of idea's need some help
Old Aug 23, 2009 | 09:34 AM
VP64's Avatar
VP64
first of all, omg u got the driver side headlamps out. im still stuck tryin to pop them out
and if the bulb isnt lighting up i would check the wires out, like checking to make sure it has a good ground and the connections
Old Aug 23, 2009 | 09:46 AM
Mega-Hemi's Avatar
Mega-Hemi
I'm hopeing you atleast checked out the fuses and relays before you started digging into the switches. I'm sure you did but with some of the people I've seen on here, you never know.
Old Aug 23, 2009 | 10:12 AM
gmb4fords's Avatar
gmb4fords
maybe a pinched wire going into that headlight? but that would have to be something you did while you were doing something under the hood or changing something. but thats all i got man, good luck
Old Aug 23, 2009 | 11:58 AM
corey600's Avatar
corey600
I just found out that there is a front control module. pulled it out it was dusty as hell blew out the connectors put it back together and it works fine now. Had two mechanics tell me it was the switches $200 bucks later it was a connection... and yes it took forever to get the bulb back in. Thanks for all the replies guy
Old Oct 8, 2009 | 11:49 PM
Shuski's Avatar
Shuski
Default 02 ram low beam out
Hi Corey, where is this front control module located, I just got my 02 ram 4x4 sport quadcab about 3 weeks ago, drivers low beam just went out tonight... also have you found instructions on the removal of the headlight to replace the bulb just in case it really is the bulb? Any help would be great! Thanks!
Old Oct 11, 2009 | 09:34 AM
corey600's Avatar
corey600
Hey man, the FCM is attached to the back of the fuse box. There is a bolt and one screw holding the fuse box in place. You need to remove the fuse box to get to the headlight bulb anyway. There are four bolts holding the FCM to the fuse box remove them and the FCM will come off. If I we're you I would start with the FCM before I touched the bulb, its a bitch to get back in! Take the neg side off you battery. Pull the FCM off if you have a air compressor blow out the connection on the FCM itself and the fuse box( Mine had a ton of dust) connect your FCM back on the fuse box and put the bolts back in but dont tighten all the way down. Put the neg side back on your battery. With mine I had to find the sweet spot if it was in to far the low beam wouldn't work. Find that spot than tighten the bolts to that spot. I work in the oldfields and my truck is offroad every day and since I have had no problems with it. I hope this helps, let me know how it works out for you
Old Oct 12, 2009 | 05:28 PM
Shuski's Avatar
Shuski
Hi Corey, Hey thanks for the reply! Well while waiting for some kind of reply from my post... I found that the headlight assembly comes out quite easy and it turned out to be just a burnt out low beam. Replaced them with PIAA M13 9007 bulbs (4000 kalvin) popped everything right back into place and all is solid and good. I will keep the information you provided ina tips and tricks file, just in case... PIAA bulbs aren't cheap but I have heard they are better resistance to vibration and humidty... Thanks again for the reply!
Old Oct 12, 2009 | 11:28 PM
rydesolow's Avatar
rydesolow
Just in my opinion, I always thought it was easier to just remove the entire headlight to replace bulbs. Just take the three bolts out using an extension from outside the headlight, pull it out, and do your business. Easy as cake.
