W/ 180 therm. why would an e-fan be beneficial?
Old Feb 24, 2010 | 07:58 AM
Nothin'_but_trucks's Avatar
Nothin'_but_trucks
Default W/ 180 therm. why would an e-fan be beneficial?
Hello all,
I was thinking about this last night as I tried to sleep and it kind of stumped me. If I have a 180 thermostat that keeps the engine around 180 why would buying an e-fan be beneficial? Is it only because it gets rid of the clutch fan to release that HP? Kind of confused on this one.
Nico
Old Feb 24, 2010 | 08:03 AM
jbrowder's Avatar
jbrowder
The 180 T Stat will keep your engine running cooler. The electric fan replaces the belt driven fan to free up horsepower. I have heard it gives you close to 10HP to the rear wheels. It should also slightly improve gas mileage. Although I havent noticed much of a difference.
Old Feb 24, 2010 | 08:04 AM
RubberFrog's Avatar
RubberFrog
The thermostat is a separate issue from the heavy rotating mass of the clutch fan.
Old Feb 24, 2010 | 08:11 AM
Nothin'_but_trucks
Sounds good, thanks guys.
Old Feb 24, 2010 | 08:59 AM
SMKNRAM's Avatar
SMKNRAM
I am seeing about 1.5 mpg improvement by the overhead I will check it manually this weekend.
Old Feb 24, 2010 | 09:29 AM
abarmby's Avatar
abarmby
Yep, removing the engine drive fan will remove the sacrificial load on the engine.
As RubberFrog said, it removes the large reciprocating mass of the fan assy.
Al.
Old Feb 24, 2010 | 10:15 AM
AF_HEMI's Avatar
AF_HEMI
10hpto the WHEELS (thats 30 crank hp), and 1.5 mpg (thats a 10-15% increase)... i call BULL!!!!! theres absoLUTELY no way it releases that much power (more like 10 crank hp, or 3-4 rwhp), and it might free up about .5 mpg (5%).
Old Feb 24, 2010 | 10:21 AM
SMKNRAM's Avatar
SMKNRAM
I make no HP claims, and qualified the mpg with I was looking at overhead. I will know more when I check it manually.
Old Feb 24, 2010 | 10:51 AM
senselesscreationz's Avatar
senselesscreationz
where can i get me one of these efans at?
Old Feb 24, 2010 | 11:07 AM
cheapbeater's Avatar
cheapbeater
you can buy a kit (flex-lite?) but they are dam expensive, or you can get one out of a 3.8L taurus from either the salvage yard or the neighbor's driveway
