Bad bad sounds
Old Feb 24, 2010 | 09:03 AM
Shiloh 24's Avatar
Shiloh 24
Default Bad bad sounds
I don't have LSD but this morning when I backed out of my drive, I heard a loud bang/pop and it did it probably three or four times. Then it did it a few times in drive. Any ideas? I'm prolly to blame for this, pay to play I guess.
Old Feb 24, 2010 | 09:09 AM
TRXHemi's Avatar
TRXHemi
See? You shouldn't have spent all that money on the engine rebuild! LOL
Old Feb 24, 2010 | 09:20 AM
cwboyjohnny24's Avatar
cwboyjohnny24
Did you check the fluid?
Old Feb 24, 2010 | 09:22 AM
abarmby's Avatar
abarmby
When you backed out.....did you have any lock put on the steering?
Judging from your post, I presume the bangs/pop's were heard from the rear of the truck?
What about drive shaft UJ's?
Al.
Old Feb 24, 2010 | 10:07 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would jack the rear axle, pull the diff cover and with the trans in neutral I would spin the tires and look.
Old Feb 24, 2010 | 10:29 AM
Shiloh 24's Avatar
Shiloh 24
I plan to jack up the *** end and do just that Weed, I'll check the gear oil first and then prolly just go ahead and change it. Gives me an excuse to throw in some RP i guess lol.
Old Feb 24, 2010 | 10:45 AM
HammerZ71's Avatar
HammerZ71
could be about anything. Gears, bearings, brakes, rotors, etc. Just gwine have to get under there and investigate...
Old Feb 24, 2010 | 01:00 PM
Shiloh 24's Avatar
Shiloh 24
I'm hoping it was just ice or something built up on the brakes that just broke free, but I'm still gonna inspect everything to be sure.
Old Feb 24, 2010 | 08:54 PM
Shiloh 24's Avatar
Shiloh 24
I got under there and looked at everything and I don't see any broken bolts or tabs of any sort, and I couldn't get the truck to make the noises again. I'm gonna pull the cover here in the next few days and see if I have any play with the carrier or ring gear, if not I'll seal it back up and fill her with some RP gear oil.
Old Feb 25, 2010 | 03:11 PM
Shiloh 24's Avatar
Shiloh 24
Couldn't get it to do it all yesterday, but this morning what do ya know. Same thing again. I'm gonna pop the diff cover and check everything out for wobble or any visible/ obvious issues. Prolly go ahead and paint my diff cover while I'm at it, would engine enamel do the trick?
