The cam is on its way!
#31
Man i was SO going to buy that OT-2 to go with my LC-1 but oh well. For his asking price I would have bought it new anyway.
Head bolts from Hensons arent but 35 bux but the gaskets are 65. Thats 100 right there. Then you still gotta buy that spring compressor. Will you need new exhaust gaskets? Because I dont think youre going to get those heads out of there with LTs still attached.......LOL
Or you can leave the heads on, get that compressor from Draggin-Accord on DT for 75 and be done with it.
#32
The tool itself worked flawless. Just make sure you roll up paper towels and put them in the oil drain holes in the heads incase you drop a keeper. If it were me and I were doing it again (which I might soon with some 6.1 heads) then i would have some extra keepers just in case. I didnt loose any of mine. I actually did drop one but I found it.
Ive got a set of extra retainers if you want a few but I dont think you will need them. If you drop one of those you can find it pretty easily.
#33
#34
Yeah because if you drop one and it goes down the head to the pan then its fishing time or drop the pan. I didnt drop one per se. Mine went flying as I had them both on the valve tip and was letting the spring and retainer back up and evidently it the keepers were not seated right on the stem and got binded with the retainer and POP!!! One went flying. Thankfully I seen where it went.
#35
Most cam numbers are with LT headers as far as i am aware of. Just keep an eyeball out for anything along those lines.
Originally Posted by OklaHemi
and teach i am getting the lt's no ceramic coating though. i dont think i will need it here in the bible belt. not a whole lot of salt or rust problems down here. i just want the exterior and interior done before i concentrate on performance. its almost there
Little FYI...Local dyno shop had a vette that was putting down 600rwhp with a set of Stainless steel long tube headers. they were all polished up nice and had that nice color change to them. He said his underhood temps went up ~40 degrees compared to stock after they were installed.
He swapped them out with the exact same headers except the new one's were ceramic coated by Jethot both inside and out. His under hood temps dropped 60 degrees compared to the uncoated one's. that means the new coated headers were 30degrees cooler than OEM headers. PLUS his dyno numbers jumped up a solid 8rwhp, just from ceramic coating.
end of story
Cearmic coating is costly, but the benefits far outweigh the cost IMO.
#37
sorry dog i should have been more clear.
i know the ceramic were put on to keep the engine bay cooler but i also know the stainless wouldnt hold up well in a east or west coast area. i think i can get the a tape kit that will hold the heat in for 80.00. i might make a phone call and see if i can get a roll free
#38
#39
Yeah, stay away from the wrap unless your a strip king. it's nothing like coating and it's a total PIA to wrap/install not to mention it's very itchy. i've wrapped a few headers in my day. Not fun at all.
Stainless T409 will create surface rust, but T304 should not. Your factory exhaust is made out of T409.
#40
Not to mentionmost headers now come with a warning saying that adding tape voids the waranty if there is any to begin with.
Teach - Congrats on finally ordering the cam. As soon as my new card gets here I'll order mine (not a Credit card but one linked to my mod account, got tired of waiting for the transfers from one to one account to another).
