cruise control problem
Old Feb 27, 2010 | 11:59 PM
basketballtitan's Avatar
basketballtitan
Default cruise control problem
when I am driving, the cruise will set like it should then about 5-10 miles down the road, the cruise will just stop working, I will begin losing speed slowly , and will not be able to get the cruise to work again unless I stop shut truck off and start again. Then will start driving again and will do the same thing. any ideas? thanks
Old Feb 28, 2010 | 12:01 AM
draco8494's Avatar
draco8494
well i cant help on the matter i can only say im with ya...if i shut my truck off with the cruise on..it wont work the next time i start it, but if i shut it off and turn it back on good to go, and if i just shut the cruise off b4 i shut the truck off its fine...kinda weird
Old Feb 28, 2010 | 02:15 AM
05RamMan's Avatar
05RamMan
Basket's problem sounds like a servo issue if you have the Hemi or possibly a vacuum issue if the other engines use vacuum. Of course that is going on not know what type of truck or engine you have.
Im sorry to say, Draco's problem sounds like it could possibly be a BCM issue. Have you tried resetting your BCM?
Old Feb 28, 2010 | 09:01 AM
basketballtitan
it is a diesel motor
Old Mar 1, 2010 | 03:12 AM
05RamMan's Avatar
05RamMan
Its a good thing they made only one type of diesel engine and put those in one Model and year, That really narrows it down.
Old Mar 1, 2010 | 08:39 AM
truckin151's Avatar
truckin151
Do a check for codes, your probelem sounds very similar to one I had a few years back. If I am correct it wont show a CEL but will throw a code.
This is going to sound like a dumb and completely unrelated question but how are your brakes?
Old Mar 2, 2010 | 08:48 AM
basketballtitan
The truck is a 2004 ram 2500, I will check the codes, and currently the brakes seem to be ok
Old Mar 2, 2010 | 08:54 AM
hoss67's Avatar
hoss67
Well at lest urs works!!!!! for a little bit, my cruise light comes on but it wont set for some reason, i was thinkin maybe a fuse or something but have no idea
Old Apr 3, 2010 | 11:37 PM
freerein100's Avatar
freerein100
I had a similar problem and found out it was my brake switch
Old Apr 4, 2010 | 12:35 AM
rocket23's Avatar
rocket23
thats whats supposed too shut them off. I always do a brake light check when i get a chance Anything reflective that will show up in your mirrors will work shop windows mirrors, whatevers out there.
