Any interest in a NEW Aeroforce Interceptor?
Here is what I dont like from them
Note that the LCD Display, the EGT and Boost sensors are optional and not needed to read the wideband air fuel ratio from the Zt-2.
Items included with each order:
Zt-2 Wideband Controller
Bosch 5 wire Wideband Oxygen Sensor
Oxygen Sensor Harness (10 feet length)
Signal Harness
Serial datalogging cable with RJ-12 to DB-9 converting plug
Datalogging software
Instructions
2 pin connector for the EGT input
Optional items which turn the Zt-2 from Wideband Air/Fuel Ratio Meter into entire tuning solution
Wideband LCD display, ZR-1, ZR-2 gauges, DashDAQ Touch Screen Display
Boost/Vacuum (MAP) Sensor
EGT Sensor
Fuel Pressure Sensor
Oil Pressure Sensor
Air Intake Temperature Sensor
Coolant Temperature Sensor
Oil Temperature Sensor
Transmission Temperature Sensor
ZAVT-1, Zeitronix Audio-Visual Warning and Trigger Box
The problem here is I want oil pressure, AIT temps, coolant temps, oil temps, trans temps which means you have to buy all of those things to get them. The sad thing is, its probably the same for the OT-1
Signal Harness
Instructions
EGT Sensor
Oil Pressure Sensor
and to monitor all those, you need gauges for all of them (or just one Aeroforce). It would be the same with the LC1.
The Aeroforce is really a good deal for all the stuff you get with it. Maybe after I get this wideband/datalogger all set up and the tuning complete, i'll drop the $240 for the AI to get the rest of the stuff covered
You dont need the gauges unless you want them all. Remember, everything would be logged. You could use the ZR-2 gauge if you wanted or the Zeitronix Wideband LCD Display
NEW ZR-2 Multi Gauge
- One gauge for displaying Wideband AFR / Lambda, Boost / Vacuum, EGT, and "User2" input (air/oil/transmission temperature, fuel/oil pressure, or voltage)
- 4 digit readout (available in Blue or Red)
- Stylish, machined, brushed aluminum or anodized black bezel and slim enclosure gives the gauge an elegant appearance
- User configurable outer LED and inner digital readout values via a front push button
- Gauge startup setup is configurable
NEW!!! Zeitronix Wideband LCD Display Features
- Display LCD top line as: Lambda and AFR / User2 and AFR / Lambda and U2 (User2).
(User2 can be setup as: Oil/Air/Water Temperature, Oil/Fuel Pressure, and Boost!
- Display LCD bottom corner as Boost, Throttle Position, or User1 (0-5 volt sensor).
- Display in imperial or metric units.
