Question for those w/ subs
Old Mar 7, 2010 | 11:44 PM
BlakeCP29's Avatar
BlakeCP29
Default Question for those w/ subs
I just got my Ram and am installing my 2 12" subs into it. I need a good crossover so i dont blow my factory speakers. What is a good, but not too expensive crossover? And i've never installed a crossover before, how difficult is it? any DIY's? Thanks guys
Old Mar 8, 2010 | 07:28 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you have a aftermarket headunit, just use the crossover thats built-in. If not, IDK. I havent used a separate crossover in years.
Old Mar 8, 2010 | 10:45 AM
casper3380's Avatar
casper3380
weedahoe is right, what is the full description of your system as it sits with the subs installed and what runs them.
Old Mar 8, 2010 | 12:36 PM
oefootball_70's Avatar
oefootball_70
Just put bass blockers on the factory speakers thats what I did.
Old Mar 8, 2010 | 12:46 PM
dirtydog's Avatar
dirtydog
Moderate User
If you have an aftermarket HU then you can set the parametric EQ to X-over above 80hz or even 100hz. That will eliminate any lower frequencies from being played through your factory speakers without the need for bass blockers because essentially it is the same thing.
Old Mar 8, 2010 | 12:48 PM
oefootball_70
Cool, good to know. I have the bass and treb that I can adjust. If I adjust the bass to that high will no bass come out of the subs too? I am a newb on most parts of stereos, just not the installs lol.
Old Mar 8, 2010 | 12:52 PM
dirtydog's Avatar
dirtydog
Moderate User
Most aftermarket HU's have a seperate filter for subs. Most have 3-band parametric eq's for front/rear highs as well as a seperate or subwoofers.
For setting up the highpass crossover for the small speakers, you want to set them at 80 or 100hz. That allows all frequencies ABOVE that to be played and heard and block everything below that point. Most 6.5's and 6x9's should not be set anything below 80hz generally speaking unless you have high end stuff where they can play that low.
Lowpass sub filters work opposite, by setting the sub to 63hz or 80hz you essentially allow the sub to play all tones Below that frequency and nothing higher.
The bass blockers are the final ruling of your speakers IF you have them installed. meaning that if they are preset for blocking anything under 100hz and you set your HU to 60hz, the speakers will only play above the 100hz and block the 60-99hz sent from the HU.
Old Mar 8, 2010 | 02:12 PM
BlakeCP29's Avatar
BlakeCP29
Whats a good head unit thats not super expensive that has the 3 filters?
Old Mar 8, 2010 | 02:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
almost every HU out now-a-days has them
Old Mar 8, 2010 | 03:57 PM
BadHab1t's Avatar
BadHab1t
ill tell ya on my sony i have in my car it doesnt and i payed 150 2yrs ago for it...now my kenwood in my truck allows for up to 120khz and as low as 60 for my subs i can pretty much adjust every parameter in this thing....but i also payed 600 or so 4yrs ago....now stereos are cheaper and for that price now i could have a flip out or dual din dvd....i should have waited....or this one needs to blow up and i can cash in on the warranty...gotta love best buy....
