Question about cost of Front Hub bearings?
Old Mar 8, 2010 | 10:26 PM
NYPANAMA42's Avatar
NYPANAMA42
Default Question about cost of Front Hub bearings?
Might have to replace the Front LEFT HUB BEARINGS.......What is the usual cost for this, including parts? I might as well do both left and right, so cost for both would be helpful.
Thanks.
Last edited by NYPANAMA42; Mar 8, 2010 at 10:28 PM. Reason: add additional information.
Old Mar 8, 2010 | 10:56 PM
Bent's Avatar
Bent
no idea as to the cost - but I'm getting a noise from my front left side that sounds like brakes dragging... What were your symptoms?
Old Mar 9, 2010 | 12:05 AM
NYPANAMA42's Avatar
NYPANAMA42
Actually, the same sound, like brakes dragging....
They took off the wheels, and checked the brakes. Brakes are fine...Turned the wheel without tire on it, and heard a grinding noise.
Have you checked to see how much your would cost?
Old Mar 9, 2010 | 12:13 AM
bigdaddyII's Avatar
bigdaddyII
I just changed the passenger side on a few weeks back. The part was $185 at Oreilly, this is for the National made on. They do sell cheaper chinese ones, which I went with originally but it went out within 2 weeks, so i brought it back under warrenty and paid the extra for the National one.
Old Mar 9, 2010 | 12:46 AM
Drangiz's Avatar
Drangiz
I've done this myself twice now. I recommend going to Autozone and getting the Timken ones. They are made in America, have a 1 year Autozone warranty and a 100,000 mile Timken warranty on them. They cost exactly 187 bucks a piece if I remember right. Doing it myself, I had the part cost plus some beer for my buddies helping me, heh. My local shop, who I trust implicitly, wanted a total of 650 bucks to do both. I only changed the one bad one, and saved myself 400+ dollars. Be warned, it can be a real pain to do though. Getting a steel hub out of an aluminum knuckle is pretty dumb most times, due to the galvanic welding that goes on.
Old Mar 9, 2010 | 02:38 AM
Kamel87's Avatar
Kamel87
i bought two off ebay for 150 for both
Old Mar 9, 2010 | 05:07 AM
HammerZ71's Avatar
HammerZ71
Get the Timken ones if you can afford it, you'll NEVER have to worry about them again!
Going rate is around $200 per and if you can't/won't do the work yourself, then figure about $150 a side labor at a good quality shop.
Old Mar 9, 2010 | 05:43 AM
bigdaddyII's Avatar
bigdaddyII
They are not hard to do. I had forgotten about the ones on ebay. There is a Dodge dealer on there selling OEM ones for $80 or so a piece. I can't link to it now because searching ebay on a blackberry bites. I knew about them when I changed mine but didn't have time to wait for it to come in, hence the chinese bearing I had originally installed.
Old Mar 9, 2010 | 06:27 AM
marky0304's Avatar
marky0304
I had both of mine replaced at the same time. I got lifetime warranty hubs from Carquest for $212.00.
Old Mar 10, 2010 | 12:56 AM
NYPANAMA42's Avatar
NYPANAMA42
Making sure, that I am getting the right thing done, I am asking this question, which is related to the issue at hand.
It just dawned on me, that a couple of weeks ago, we had a several bad snow storms one after the other. After one of these snow storms, the snow was packed down and became icy, which was very slippery.
One day as I was driving the truck slid sideways, and the Front Drivers side wheel struck the curb REALLY hard. I got out, checked, and saw the apparent damage, so i figured all was well.
Now I am thinking, that all of the damage was probably done to the wheel and its components.
One other thing, as i was driving tonight i noticed another thing. At 30 MPH when turning Left, I hear a "whomp, whomp, whomp, whomp" type sound which more or less sounds like a helicopter hovering...I want to make sure that i am getting the correct thing fixed. Is this the Hub bearing which is damaged or some other component?
Thanks in advance.
