Sluggish Hemi
Old Mar 9, 2010 | 05:21 AM
RobertD's Avatar
RobertD
Default Sluggish Hemi
My 2004 dodge ram 5.7l is running sluggish. I replaced the factory plugs 50,000 miles ago, and again 140,000 miles with platinum plugs and it is still running sluggish. Can anyone tell me where I should look next? Coil pack, injectors???
Old Mar 9, 2010 | 05:31 AM
RedTruck-VA's Avatar
RedTruck-VA
Have you looked at the air filter, dirty TB? Any codes showing? egr? I have heard here that the Hemi doesn't like the platinum plugs, maybe try copper coats. Wires and coils I think will throw a code.
Old Mar 9, 2010 | 05:36 AM
RobertD's Avatar
RobertD
No codes or indicator lights. I was thinking of a bad coil or injector but i figured it would throw a check engine indicator. I had replaced the stock plugs with more stock plugs and had the same issue (champion plugs). I will check the filter and egr.
Old Mar 9, 2010 | 05:42 AM
RedTruck-VA
The TB often needs cleaning as miles accumulate. Fuel filter could also slow the engine down.
Old Mar 9, 2010 | 05:54 AM
HammerZ71's Avatar
HammerZ71
If you've gone much more than 30k miles since your last TB cleaning, that's the first thing I'd try. I clean mine every 15k which is about every two years for me and it's pretty gunked up even at that interval...
Old Mar 9, 2010 | 05:59 AM
RobertD's Avatar
RobertD
I appreciate yall's help on this....I will check it out first thing when I get up this afternoon.
HammerZ71--is it hard to remove the TB??
Old Mar 9, 2010 | 07:14 AM
jk360's Avatar
jk360
nope, take of your intake, remove the wire clip from the TB, then take the 4 bolts out with a 8mm socket and it comes right off. i just did it friday. i used non-chlorinated brake cleaner and sprayed a rag, not directly on the tb cause i didnt wanna screw up the electrics. when you first see it it doesnt look dirty till you turn it around!
Old Mar 9, 2010 | 08:04 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I agree, plugs, wires, TB, EGR, PCV, good fuel, air filter, good tire pressure
