exhaust question
Old Mar 9, 2010 | 07:12 PM
beachbummer0069's Avatar
beachbummer0069
Default exhaust question
hey, I'm thinking about removing the cats and installing glass packs in place of the two cats. i was wondering what is the stock exhaust pipe size? Also, do i need to buy one or two sets of the spacer things that move the O2 sensors out of the path of the exhaust?
Old Mar 9, 2010 | 07:48 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
those better be some short glass packs you are going to try to put in place of the cats because the pipe bends right there at the cats. And dont glass packs go at the other end of the exhaust? The pipe for the cats is 2.5" I think but I know after the Y it is 3"
And yes if you lose the cats you will need the non-foulers to try to trick the O2's
Old Mar 9, 2010 | 08:04 PM
beachbummer0069
the glass packs are only 12 inches long. On my 03 chevy silverado I installed two glass packs in place of both cats and had no problem. If you look under neath the truck it look like cats because they were right in place of where the cats would of been.
Old Mar 9, 2010 | 08:11 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Why are you replacing the cats with glasspacks? Are you just trying to get rid of the cats and need something to put in their place?
The non-fouler trick works good, I am currently running them on the passneger side of my exhaust bc the high flow cats threw a code on that side.
Old Mar 9, 2010 | 08:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
On one of my cats the is barely any pipe that comes out of it before it does a sharp bend. IDK if youre going to be able to lput anything there in its place. And again, dont glasspacks go at the other end of the exh?
Old Mar 9, 2010 | 08:18 PM
Off_Road_Teacher
Here is a pic of the stock cats. I am not sure how you are going to fit a glasspack in there without having to do some fabbing.
Old Mar 10, 2010 | 07:34 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
THX for those pics. Thats exactly what I was talking about. And thats not no thin pipe either. It took a few mins for my sawzall to go through it.
Old Mar 10, 2010 | 05:01 PM
beachbummer0069
The glass packs are only 8 inches long. Also, on the passenger side cat the sensor that is on the cat. Is that an O2 sensor?
Old Mar 10, 2010 | 09:19 PM
meen green machine's Avatar
meen green machine
correct me if im wrong i heard on the new trucks it could mess up the motor or something like that by removing the cats. If not i would like to gut mine
Old Mar 10, 2010 | 09:52 PM
Animal Mother's Avatar
Animal Mother
yeahhh **** the ozone!
