2wd 2500 rack and pinion
Old Mar 14, 2010 | 11:03 AM
Beastro's Avatar
Beastro
Thumbs up 2wd 2500 rack and pinion
Well I have been looking for a stronger rack and pinion for my 1500 (trade in value to low so have to keep the truck) and I found that the 2500 2wd has a HD rack and pinion. yes the srt10 rack is strong but they want 200+ for it. I dont know if the 2500 rack will fit the 1500 I need to compar the 2 but this is somehting to look at for all the guys running bigger tiers and haveing problems with the 1500 rack.
Old Mar 14, 2010 | 11:40 AM
shortburb's Avatar
shortburb
I just replaced the rack in my 04 1500. It was $210 from napa.
Ill be watching this thread
Old Mar 14, 2010 | 01:08 PM
Beastro's Avatar
Beastro
UPDATE: I called up auto zone to see if the 2500 rack would fit it will same numbers. They priced it at 180 and 110 core charge. SO 4X4 1500 owners you can get a stronger rack and pinion for our trucks! I havent been able to find anyhting on the net of anyone doing the swap but im still looking
Old Mar 14, 2010 | 01:17 PM
lxman1's Avatar
lxman1
Site Moderator
I didn't think 2500's had a rack and pinion. But I dunno.
Old Mar 14, 2010 | 01:23 PM
shortburb's Avatar
shortburb
actually that makes sense. 2500s are solid axle on the 4wds right? That would mean gear box and linkage.
Maybe hes talking about 2wd 2500s?
Old Mar 14, 2010 | 01:55 PM
Beastro's Avatar
Beastro
Right read the title of the thread guys 2WD 2500 rack and pinion! The 4x4 2500 are solid front axels. call them up check it our for your selfs
Old Mar 14, 2010 | 07:16 PM
Beastro's Avatar
Beastro
they only down fall is that you will the the hole 2500 power steering set up. you can't just put the rack on the 1500 the 1500 pump wont be able to power it.
Old Mar 14, 2010 | 08:23 PM
RedTruck-VA's Avatar
RedTruck-VA
If they both have the same numbers, doesn't that mean they are the same part?
Old Mar 15, 2010 | 06:39 AM
Beastro's Avatar
Beastro
yes but autozone right up and dodge's right says that it is built with HD parts. I look for the site I read it on.
