Sloppy Steering
Old 03-14-2010, 08:28 PM
Slowhand12's Avatar
Slowhand12
Slowhand12 is offline
Default Sloppy Steering
Hello I was wondering if anyone else has or had this problem. I Practically replaced my whole front end.Upper and Lower ball joints and tie rods, plus both hubs. My problem is it STILL wonders on the road. Does anybody have any other Ideas.
Thanks for Your Help
Slowhand12
Old 03-14-2010, 08:55 PM
05RamMan's Avatar
05RamMan
05RamMan is offline
Did you replace Tie rods? Could also be a bad rack. Or something as simple as Needing and Alignment.
Old 03-14-2010, 09:55 PM
spoolandsmoke03's Avatar
spoolandsmoke03
spoolandsmoke03 is offline
What size tires and have you installed a steering box brace ?
Old 03-14-2010, 10:47 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Check the steering shaft as it goes into the rack and make sure it is tight. I had that come loose a bit once and has some play in my steering wheel.
Old 03-15-2010, 06:39 PM
Slowhand12's Avatar
Slowhand12
Well I did have the Tie rods replaced. My tires are 265/75/16. And I am at the moment getting a alignment done. Because after going for a totally new front end job I was a little disappointed. I'll report back as soon as it comes back from the Doc's. Thanks for everyone's Help.......................Slowhand12
Old 03-16-2010, 09:32 AM
05RamMan's Avatar
05RamMan
05RamMan is offline
Its not an entire front end job until the alignment has been done.
Old 03-16-2010, 12:44 PM
cwboyjohnny24's Avatar
cwboyjohnny24
cwboyjohnny24 is offline
You run 16 inch rims??
Old 03-16-2010, 07:17 PM
Slowhand12's Avatar
Slowhand12
Yes I do run 16" wheels. And I just got the word AND I need a new steering Box. So that just about covers it A WHOLE new front end. I guess the only think good about is I took out the Extra warranty Ins. But still its not cheap........Slowhand12
Old 03-16-2010, 07:22 PM
ramhunter9's Avatar
ramhunter9
ramhunter9 is offline
spot on weed
had the same problem
Old 03-16-2010, 07:24 PM
new2this's Avatar
new2this
new2this is offline
ramhunter is back? when did this happen? sorry, didnt mean to thread jack. just got caught off guard
Quick Reply: Sloppy Steering
