Need Help NOW!!!
Old Mar 17, 2010 | 06:56 AM
  #21
JoeHemi's Avatar
JoeHemi
Man I feel for you....you've had some serious bad luck lately. Hopefully this wont break the bank trying to fix
Old Mar 17, 2010 | 07:56 AM
  #22
bigdaddyII's Avatar
bigdaddyII
Will be interested in the outcome of this as I have been having that "feeling".
Old Mar 17, 2010 | 01:14 PM
  #23
05hemi05's Avatar
05hemi05
well i checked it out this morning, fuses were fine and the fluid was fine too(correct level and no discoloration or smell). So the more i thought about it i realized maybe its a u-joint? idk, seems like its something with the driveshaft like dirtyjohn said. I had it towed to the shop around 9 this morning, they're putting on the gas level sensor that they didnt get around to last time, the bleached fried the old one up. and after that they're gonna start lookin into this new problem, as soon as i hear something ill let you guys know.
Old Mar 18, 2010 | 10:58 AM
  #24
05hemi05's Avatar
05hemi05
just an update for you guys, it turns out its not the driveshaft, the shop its at now doesnt do transmissions so ill be getting it towed again to my local transmission shop. I already talked to the guy there and he said it sounds like it could be torque converter or transmission fluid pump, hpefully thats all it is or ill be forking over some money for a new transmission.
I should be finding out what is causing this today, as soon as i do ill get back on and let you guys know what it is.
Old Mar 18, 2010 | 10:29 PM
  #25
V_Scapes's Avatar
V_Scapes
Dang this sucks.
I was thinking though even if it does have 67k on it you dont know what the guy before you did with the truck. He could have done some serious towing or hauling or just ripped the thing around all the time and now your stuck with the issues. It sucks to not have a warrenty but when you buy the truck from a dealer you dont know who had the truck before you.
Old Mar 18, 2010 | 11:41 PM
  #26
05hemi05's Avatar
05hemi05
well the transmission shop ran diagnostics on it and it turns out its something internal. So starting tommorow they'll be tearing apart the tranny to figure out exactly what it is. Ive been tryin to be a little optimistic about this whole situation though so tommorrow ill be givin them a call about possibly upgrading to 4.56 gears and LSD while they've already got the thing apart there's a chance i might actually get insurance to cover this too so maybe this wont turn out bad after all lol ill be back with another update once i hear EXACTLY what happened to it.
Old Mar 18, 2010 | 11:58 PM
  #27
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
umm, 4.56 gears don't have anything to do with the transmission. but you certainly should upgrade the trans and/or TC while they're in there.
got 105k on mine, I don't think twice about flooring it...well, cept the fuel
Old Mar 19, 2010 | 12:05 AM
  #28
05hemi05's Avatar
05hemi05
Originally Posted by xfeejayx
umm, 4.56 gears don't have anything to do with the gears. but you certainly should upgrade the trans and/or TC while they're in there.
dang, im confused now, if there's one thing i dont have any experience in when it some to vehicles its trannies lol so how do the gears work? if i want to upgrade to 4.56 would i have to get a whole new transmission? and about how much would a new TC run and exactly what benefits would i get outa that, more power to the wheels im guessing?
i never thought twice about flooring it before either but after this you can bet ill probably never WOT again, at least with the stock tranny, its sad
Old Mar 19, 2010 | 12:30 AM
  #29
RedTruck-VA's Avatar
RedTruck-VA
05Hemi, do you have anyone you can call to help you through this that has automotive experience? I say this only because you have a serious problem with the trans being tore down and there are some decisions you need to make about your truck's repair. The learning curve during a crisis is pretty damn steep. There is an oportunity if the the torque converter needs replacement to upgrade to a high performance converter. Good luck...
Old Mar 19, 2010 | 01:04 AM
  #30
truckin151's Avatar
truckin151
4.56's are the gears in your rear differential.
