Huh. So, it *is* "Heavy Duty"
Old Mar 17, 2010 | 05:58 PM
Bigc9164's Avatar
Bigc9164
i have had almost 1900 pounds in the back of my 1500 reg cab short bed with the 4.7 and it handled it NO problem...there was a bit of sag! but with my e rated nitto terras it was completely fine!!!
Old Mar 17, 2010 | 06:16 PM
Rojhan's Avatar
Rojhan
"After":
You can click on each pic for slightly larger versions.
I'll get the before pics up... after...
Old Mar 17, 2010 | 07:34 PM
shortburb's Avatar
shortburb
When I first got my truck (1500 4wd 5.7) I got the bed topped off (level with the top of the bed) with 2 inch rocks for a landscaping project I was working on.
Suspension bottomed out, tires near flat (with 50psi in them)...it was a slow ride home. The motor and trans carried it well. The suspension did not.
I have a pic somewhere Ill see if I can dig it up.
Old Mar 17, 2010 | 07:48 PM
OICUDRIVE12's Avatar
OICUDRIVE12
By ratings on the side of the truck 1500,2500,3500
(1/2),(3/4),(1/1)- Ton
I thought these were the weight ratings of what the "Pay Load" is on the particular truck.
2000 pounds in the bed is alot of weight, but even my 1500 will carry it but its not the taking off or hauling its the stopping and steering that suffers.
Old Mar 17, 2010 | 08:56 PM
Rojhan's Avatar
Rojhan
1500,2500,3500 and 1/2,3/4,1-ton used to be more closely related, but as consumer demands have grown and manufacturing has advanced, they are... more like guidelines. My "3/4-ton 2500" has a rated payload of 2,700 pounds. Not quite double "3/4-ton".
The increasing numbers still represent an increase in capacity, but you have to actually check specs now.
Old Mar 17, 2010 | 09:04 PM
Rojhan's Avatar
Rojhan
Measuring from center of axle to top of wheel well.
Empty: 40-1/2" front, 40" rear.
Full: 41-1/4" front, 38-1/2" rear.
The front did come up a little bit, but it was till nose-down overall.
Old Mar 17, 2010 | 09:10 PM
OICUDRIVE12
Thnx for the info. Thats why I'm here to learn small stuff like that.
Alone we are just 1 but together we are many. LMAO.
Old Mar 17, 2010 | 10:03 PM
RedTruck-VA's Avatar
RedTruck-VA
Very impressive, those are real trucks....
I didn't think you could actually put stuff in the bed.. well I do put a case of oil and a filter or two at times in there.
I guess thats why I have mine covered up.,,,,
Seriously, I occassional pull an enclose 12' motorcycle trailer. But that is as much work she ever gets.
Old Mar 18, 2010 | 01:12 AM
gasguy's Avatar
gasguy
nice lookin' truck!!
Old Mar 18, 2010 | 12:15 PM
Rojhan's Avatar
Rojhan
FWIW - braking was noticeably different (not in the least "bad" or "scary", just different). Handling was the same. The ride was a bit smoother with the rear spring compressed.
Gasguy - not bad for stock
