April 3rd gen OTM
Old Mar 26, 2010 | 07:09 PM
  #231
AF_HEMI's Avatar
AF_HEMI
you bring a valid point. well good luck man. dibs on your truck if you survive this build, we better be gettin some pictures!
Old Mar 26, 2010 | 07:13 PM
  #232
ramhunter9's Avatar
ramhunter9
Or frog legs!!!
Old Mar 26, 2010 | 08:57 PM
  #233
Mega-Hemi's Avatar
Mega-Hemi
Originally Posted by RubberFrog
I can't change the box any easier than changing the breaker- I have no master disconnect.
Will the elec. co. charge you to come out and pull the meter? Just long enough to put a new main in anyway. That's really not safe for anyone to be working on. You'll be lucky if it throws you accross the room and doesn't stick you to it.
Old Mar 26, 2010 | 09:16 PM
  #234
reefguy89's Avatar
reefguy89
its only 240v u will be ight. just use a screwdrive with a nice rubber handle.
Old Mar 26, 2010 | 09:18 PM
  #235
JoeHemi's Avatar
JoeHemi
Old Mar 26, 2010 | 09:19 PM
  #236
ramhunter9's Avatar
ramhunter9
LMAO^^^ nice pic
Old Mar 26, 2010 | 09:32 PM
  #237
SMKNRAM's Avatar
SMKNRAM
frog just pull your meter yourself, then when you get the new breaker or box whichever, you just plug your meter back in
Old Mar 26, 2010 | 09:42 PM
  #238
Bluesmanjesse's Avatar
Bluesmanjesse
Frog don't pull the meter unless you got a good story for the power company as to why you cut the tag off. You'll be fine just go slow and be careful,for a little added insurance wrap the whole shaft of your screwdriver with electrical tape except for the very tip. I've changed hundreds of those pushmatic breakers hot with out any problem,they were the cadillac of thier day,the only downside now is replacement breakers are expensive and hard to find.
Old Mar 26, 2010 | 09:49 PM
  #239
SMKNRAM's Avatar
SMKNRAM
he is the master story teller!! he can pull out one of those ladie pics he has and they wont say anything to him!!
Old Mar 26, 2010 | 09:55 PM
  #240
RubberFrog's Avatar
RubberFrog
Great idea on wrapping the shaft, thanks. Knowing this area, I'd probably get prosecuted for power theft if I pull the meter! Believe it or not, homedepot now carries the breakers in stock. I've only had one go bad in the 5 years I've owned this place and the box is in great shape. Clean, no corrosion, no rust, etc.
