bought a 2.5" levelin kit.... got one question
Old Mar 20, 2010 | 09:00 PM
hoss67's Avatar
hoss67
Originally Posted by ramhunter9
just get ones that are for the amount of lift . if you did a 2.5 lift get a 3" lift shock you will be fine . since shocks dont come in half sizes 2.5 isint a option . get 3" longer lift shock you will be fine
Thank Dude! i owe ya one
Old Mar 20, 2010 | 09:04 PM
rocket23's Avatar
rocket23
Rh you gotta get into his world them shocks as you call them are STRUTS they go in side his coil springs and have a flange welded in the middle of them. those f%$kers are 110 a piece and those are the stock ones the over sizes are gonna be more and they are a pita too r/r! rear shocks are a breeze at 49 bucks a pop.
Old Mar 20, 2010 | 09:05 PM
hoss67's Avatar
hoss67
I found some rancho for 36$ a piece, but they are for 2500 and 3500, would they fit or do i need to find them for a 1500?
Old Mar 20, 2010 | 09:06 PM
LinerJoe's Avatar
LinerJoe
I will counter what is being said here. Note, this information is for 2006+ 1500's (non-mega cab).
If you are adding a coil spacer (such as a 2.5" spacer), then you do NOT want to get longer shocks/struts. That will just make the lift higher (which isn't good, because 2.5" is max with this type of lift).
If you get longer struts, then you should NOT have the coil spacers installed. In other words, if you get the Bilstein or Rancho lift shocks (which are longer), then you would not use a spacer with them.
This information comes directly from Bilstein and Rancho, along with Moe's Performance.
I recently went through this. I had put on a 2.5" coil spacer last year, and wanted new shocks this year. I assumed I needed longer shocks as well, but that was not the case.
Also, you will notice that your shock choices are very small compared to the pre-strut setup and the 2500's.
I would recommend you call around and gather information as well. Don't just believe all our of our answers.
joe
Old Mar 20, 2010 | 09:07 PM
ramhunter9's Avatar
ramhunter9
$hit ...i got to reading after that you are right i was thinkin he had normal coil springs and shocks ..crap my bad i apologise man i miss read .
rocket23's Avatar
rocket23
read previous post/btw how the f$#k did you get to professional wtf I got five times the posts lol j/king really///....
Old Mar 20, 2010 | 09:14 PM
hoss67's Avatar
hoss67
joe
Ok let me get this straight..... so since i have a coil spacer ( the 2.5" level) i do not need longer struts? is this correct? do i need to do anything when i put the 2.5" level on? as for the other comment, the number of posts dont mean anything brother
Old Mar 20, 2010 | 09:15 PM
hoss67's Avatar
hoss67
hahaha dude i have no idea, i mis read ur post for a second in my previous post, but i have no idea, i guess i am just that good
Old Mar 20, 2010 | 09:23 PM
rocket23's Avatar
rocket23
On second thought maybe I skipped being a pro and went right too captain staus lol
anyway yes your good with your stock struts however get them changed if over 50k mine are stock and I can feel the boat bounce it's there but I can live with it for another year /did too many mod.s too quick.lol
Old Mar 20, 2010 | 09:26 PM
ramhunter9's Avatar
ramhunter9
explain to this ol fart how you guys have struts?? i had a 04 that had IFS with springs and shocks , never knew they had struts like a car?
