Clunking sound going over bumps!
Old Mar 29, 2010 | 01:20 AM
dylansav's Avatar
dylansav
sorry for the late reply. So I went and took it to a shop and they told me that both sway bar links and tie rods are busted. The sway bars need replacing and the tie-rods are on the way down. They're total estimate = $950. I looked up the price of parts at our local parts dealer and he said brand new and top of the line = ~$300.
Now If I can save $650 and not give it to these guys, i'm going to do it.
My final question is... Is it do-able to replace both tie rods and sway bar links at home?
Old Mar 29, 2010 | 04:42 AM
RamMN's Avatar
RamMN
sway bar links are easy...doesn't look like maxxlinks sells a set for a regular height 2006 Quad Cab?
Old Mar 29, 2010 | 06:24 AM
greenpigs's Avatar
greenpigs
I have a similiar sound in mine so I guess it could be at least two things that need checked.
Old Mar 29, 2010 | 06:50 AM
RedTruck-VA's Avatar
RedTruck-VA
My thoughts are you need another shop. You don't replace the sway bar. It is only the two end links need a couple of bushings. Tie rod ends is a little more work but still not a big deal. Shop around or do it yourself.
Old Mar 29, 2010 | 07:30 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would definitely do it myself nd then take it to a shop for an alignment
Old Mar 30, 2010 | 02:15 PM
dylansav's Avatar
dylansav
thanks for the help. We are going to attempt at doing this ourselves. If you guys have any pointers at tackling this, let me know. We'll be using the Chilton manual with Alldata online to guide us but I would love some advice!
Old Jul 11, 2010 | 10:35 AM
Jromano28's Avatar
Jromano28
It's the sway bar bushings guys cause I have charger and I've had the same issues and no more problems and the sway bar links also
Old Jul 11, 2010 | 10:41 AM
03MopaRamman's Avatar
03MopaRamman
Agree with all and DIY as per Weeds suggestion, and stock Car Alignement (set Tie Rods to the same thread count) to get you to the Shop for the alignement.
Old Jul 11, 2010 | 01:04 PM
Az Rob's Avatar
Az Rob
SAFETY NOTE: When replacing stabilizer bar bushings, be sure that both front wheels are either on the ground or in the air. Otherwise, the sway bar will be spring loaded. With only one wheel jacked up. Removal of the either nut on the top of the stabilizer link could result in a serious injury.
