seperate battery?
Old Mar 29, 2010 | 09:40 AM
meen green machine's Avatar
meen green machine
Default seperate battery?
ok so i had some cheap offraod lights from walmart behind the grill before. they were wired to the truck battery along with an amp. well i started getting weak starts and it turns out the lights killed my battery. I was told the make specail battery's for things like lights and stuff so u dont use the truck battery. is this necessary? I got a grilleguard and want to get some of the Hella 500's on there but i dont want to have to ruin another battery. any ideas?
Old Mar 29, 2010 | 10:13 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive got a drivers side batt box if you want.
Old Mar 29, 2010 | 11:45 AM
nim81's Avatar
nim81
i have a 1000w amp, and 4 hella 500's all on my battery, no problems.....
you could also get yourself a marine battery. should be more than enough.
Old Mar 30, 2010 | 06:12 PM
meen green machine
weed are talking about for holding another battery plus the one thats already in there?
Old Mar 30, 2010 | 06:15 PM
rocket23's Avatar
rocket23
I would do a voltage check your bleeding volts somewhere dunno where but you kill batteries by using them w/out recharging them.
Old Mar 30, 2010 | 06:56 PM
ramhunter9's Avatar
ramhunter9
yellow top . imo are the best .
and weed if he dont want it i could use it ...2 batterys sounds like fun
Old Mar 30, 2010 | 08:17 PM
nim81's Avatar
nim81
go for 2 deep cycles !
Old Mar 30, 2010 | 08:21 PM
hemiguy0302's Avatar
hemiguy0302
Anything optima seem to be **** from the experience I have had with them. In all honesty the best batteries I have bought were Interstates or AC Delco. Both cheaper and both last longer. But if you want the purple koolaid optimas then go for it.
Old Mar 31, 2010 | 08:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, two batteries. I have two. One on the D/S and one on the P/S. Both are 1000 CA's each and wired together on my stock 136a alt with no issues.
PM sent
Old Mar 31, 2010 | 09:44 AM
ramhunter9's Avatar
ramhunter9
let me do some lookin under the hood see if i could fit her weed .
