Codes P0344 P0016
Old Mar 31, 2010 | 10:56 PM
Jose Cuervo's Avatar
Jose Cuervo
Default Codes P0344 P0016
I just had the 4.7 in my 04 Ram rebuilt after it threw a rod. I put the engine back in and started it with no problems until the check engine light came on after a few minutes. I scanned it and got codes: p0344 (camshaft position sensor) and P0016(crankshaft position sensor). After I stopped the engine and cleared the code, the engine would not start anymore. I then replaced both sensors but am experiencing the same problem. It starts at first but then will not start again for a while.
Has anybody else experienced this?
Old Apr 1, 2010 | 05:12 PM
nh5's Avatar
nh5
I'll bump this for ya since some people might have missed it, But after the rebuild did you check the timing? I think these might be caused by the timing being out.
Old Apr 1, 2010 | 06:07 PM
lxman1's Avatar
lxman1
Site Moderator
Check the wiring harness and make sure something didn't get pinched when reinstalling the engine.
Old Apr 1, 2010 | 06:27 PM
Jose Cuervo
The shop put the timing cover back on when they assembled it so I didn't get a chance to check the timing. It does idle smoothly though.
I'll check the harness and grounds first then I'll pull the timing cover if necessary.
Thanks for your help.
Old Jun 15, 2011 | 11:30 AM
gabriel mendez's Avatar
gabriel mendez
I have the same problem with this code p0016, p0344, p0038, i rebuilt the engine, the revolutions dont pass the 3000rpm, the smoke is very black, to start the engine is hard, i check the timing and all is there place
Old Jun 15, 2011 | 01:02 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
thick black smoke, hard to start......running rich? Not where I can check the codes right now but have you went through and double checked all your electrical?
Old Jun 15, 2011 | 01:10 PM
gabriel mendez
yes is running rich, i will check all the electrical, thank
