HEMI Flowmaster 40 Series
Old Apr 3, 2010 | 11:30 PM
Straightedge's Avatar
Straightedge
Originally Posted by rocket23
did you try to reset the settings with a battey un hook?? leave the neg off for five minutes this forcesthe ecm too relearn the different settings it is facing
Just did that and still the same problem...
Old Apr 3, 2010 | 11:36 PM
rocket23's Avatar
rocket23
I'm at a loss first I heard of your problem really don.t think it's the fm thou
Old Apr 3, 2010 | 11:43 PM
Straightedge
Would getting a tuner so I could up my idle speed do me any good? and if so what would be a good one to get?
Old Apr 3, 2010 | 11:51 PM
JoeHemi's Avatar
JoeHemi
no, it might mask the problem but theres still a problem. The shop you took it to, was it a dodge dealer? There might be a flash update for your truck that you need from the dealer. Throwing any codes? Something isnt really adding up. One way to test is just cut off the muffler and see if you experience the same problems. Maybe an exhaust leak somewhere else? Intake leak? I really dont think its your muffler but something else is at the root of the problem.
Old Apr 4, 2010 | 12:11 AM
Straightedge
Yeah it was a dodge dealer and I've taken it there 4 times and they have said each time it's not throwing codes and there are no updates.... I thought about cutting the muffler off just to see so I might try that tomorrow.
Old Feb 9, 2013 | 03:01 AM
erincastillo's Avatar
erincastillo
IAm having the same problem !!! Help me ! What happen?
Old Feb 9, 2013 | 07:50 AM
HammerZ71's Avatar
HammerZ71
Same old question. Do a little research:
https://dodgeforum.com/forum/3rd-gen...mparisons.html
Old Feb 9, 2013 | 04:09 PM
ricow82's Avatar
ricow82
Ok didn't know that probaly should but got flow and truck runs like crap ? Change it back?
Old Feb 9, 2013 | 04:11 PM
ricow82's Avatar
ricow82
I am having problems with my truck after changing exhuast runs sluggish
Old Feb 9, 2013 | 08:17 PM
lxman1's Avatar
lxman1
Site Moderator
Reset the PCM so it can relearn the adaptive tables. Unhook your battery for about 60min.
After you unhook the ground cable, turn on the headlight switch. This will help discharge any capacitors in the PCM.
Then after 60 min, turn off the light switch and rehook the battery. Drive it awhile so that the PCM can relearn the adaptive tables.
Anytime that you do a mod like an intake or exhaust, it is best to do this. The PCM will adapt to the changes faster this way.
I would highly recommend Magnaflow over Flowmaster. They are stainless and flow much better.
