Turn signal mod idea.
Old Apr 6, 2010 | 08:24 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ok, here is what you do. You know those 2'x4' or 2'x2' fluorescent light fixtures? You know those clear or frosted plastic covers below the bulbs? You can buy replacements at Lowes. Go get a sheet and with a scoring knife, cut you a small piece and use a dremel with a sanding drum to shape it how you want.
Get some LEDs on a circuit board or make you own with parts from ebay of Radioshack and epoxy them to the clear plastic you got from Lowes.
Get your mirror (off the truck) and remove the glass. Look at how and where you want to mount it and cut the backside of the mirror housing. I would drilla 3/8" or 1/2" hols and then use my dremel with a carbide bit and sanding drum to cut out and shape the area where I am going to mount the plastic cover and LEDs. Then use either more epoxy or JB Weld to mount it in the mirror housing.
This will allow you to mount it FLUSH with the mirror housing and give the best look possible. If you get creative you can make whatever shape or symbol you want and mount it in the housing.
Old Apr 6, 2010 | 09:07 AM
Rojhan's Avatar
Rojhan
Last time I looked at the schematic, I don't remember the turn signal power going into the mirror harness, and there was no obvious way to run wire through the double-pivot of the towing mirror.
I still like the height near the bumper better.
Old Apr 6, 2010 | 11:07 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I promise you that you can run a wire through the door and to the turn signal wires in the D/S kick panel or lights. Trust me, it can be done. ;-)
Old Apr 6, 2010 | 10:15 PM
WhiteRamTRX4's Avatar
WhiteRamTRX4
Are you talked about drilling through the actual mirror? Is this possible without breaking the glass?
Old Apr 7, 2010 | 07:03 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I think you and I are talking about two different things here. I am talking about cutting a small section out of the mirror HOUSING and adding a lens with LEDs back there. I think you are talking about putting LEDs behind the mirror to shine through the mirror????
That can be done also but in either case you would not drill a hole through the glass. You would follow the same path of the wires that are in the mirror for the heat or motor adjustment
Old Apr 7, 2010 | 09:25 AM
TRXHemi's Avatar
TRXHemi
Demon-Hemi on DT did it in his tow mirrors. It looks pretty good. He did them on the side of his tow mirrors....not sure if this is what you want to do....
Old Apr 7, 2010 | 02:06 PM
espinosafell's Avatar
espinosafell
Everybody look at this.... I posted this before and got no looks at it because Im not cool enough . This company makes the mirror with the LEDs installed and you dont have to replace the whole side mirror: http://www.muthco.com/products/kits/220-0164.htm
And for the OP I would call to see if they make ones for the trailer mirrors which I believe they can!!
Old Apr 7, 2010 | 04:11 PM
TRXHemi's Avatar
TRXHemi
Link no workie....sorry, the product you are looking for is not here.....
Old Apr 7, 2010 | 04:17 PM
ramjamhemi's Avatar
ramjamhemi
Just go to the homepage and select your vehicle. It will take you to all the different options.
Old Apr 7, 2010 | 08:26 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive seen those before but I dont want turn signals in my mirrors that bad.
$200 is way to high for me
