Rear end issue
Old Apr 4, 2010 | 09:32 PM
leemar4's Avatar
leemar4
Unhappy Rear end issue
The other night, on my way home from work, I was pulling off from a red light, and the back of my truck made a very loud clanking noise. The entire truck shakes everytime the noise happens. Unfortunately that is all I really know about the problem just wondering if anyone else has had one similar and would have any idea as to what it was. It sounds expensive whatever it is, and I am a little afraid of the truth, but I would rather go ahead and get it fixed so please if you have anything I'll listen.
Old Apr 4, 2010 | 09:35 PM
2008Dodgeramblackedout's Avatar
i hate to break the news... but mine did the same exaxt thing and it was the spyder gears in the rear end...
Old Apr 4, 2010 | 09:37 PM
kvsmith2004's Avatar
kvsmith2004
I don't know what it is man but that sucks! If you have not done a rear end service on it just open it up and check it out asap!
Old Apr 4, 2010 | 09:42 PM
leemar4's Avatar
leemar4
Spyder gears?
Old Apr 4, 2010 | 09:46 PM
Shiloh 24's Avatar
Shiloh 24
inside the carrier in the differential there are four small little bevel style gears called spyder gears.
Old Apr 5, 2010 | 07:27 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well I would definitely be pulling the rear cover and looking. You may even wanna jack up the rear axle and turn the wheels by hand.
Old Apr 5, 2010 | 07:39 AM
RedTruck-VA's Avatar
RedTruck-VA
What rear diierential do you have. My guess it is the OEM LSD clip problem. When the clip breaks it is caught in the gears, pretty much destroying the rearend. You may also get a VSS/RWAL codes as the sensor can also be damaged. My mechanic showed me a set of carrier bearing caps that were trashed and said the housing looked the same. I recommend opening it up ASAP to figure out what needs to be done for repair. Good luck....
Old Apr 6, 2010 | 08:08 PM
leemar4's Avatar
leemar4
Well after finally taking off the cover, it revealed that the spyder gears were torn to pieces... great. Thanks for all the help guys.
Old Apr 6, 2010 | 08:10 PM
matthewbeard's Avatar
matthewbeard
time to upgrade. DTT and some tall gears!!!
Old Apr 6, 2010 | 08:19 PM
flwalks's Avatar
flwalks
Do you still have a warranty on it. If so get it back to the dealer asap
