oil consumption
Old Apr 4, 2010 | 10:13 PM
super_b_car_guy's Avatar
super_b_car_guy
Default oil consumption
anyone out there have any problems with the 360 engine in a 02 quad cab? i've changed the intake, and lower plenum gaskets. its got about 93000 miles on it. any help?
Old Apr 4, 2010 | 10:15 PM
hemiyellow's Avatar
hemiyellow
DC Insider
how much oil are you losing between oil changes? how often you change it?
Old Apr 5, 2010 | 07:26 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
valve seals bad? Piston rings got too much gap? Front or rear engine seal leaking? Valve covers leaking?
Old Apr 5, 2010 | 07:44 AM
super_b_car_guy
i change it every 3K, im loosing between 2 to 3 quarts between oil changes. the rear main is seeping, but not 2qts worth, its not even leaving signs in the drive way. the front seal has been changed when i did the front cover. there is no signs of it leaking at the valve covers. i think its time for a rebuild. now if i can only get the $$$ for it.
Old Apr 5, 2010 | 08:58 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, sounds like you are leaking internally and burning it. Look around on CL for a cheap engine to either rebuild or use as is and build your current one
Old Apr 5, 2010 | 06:23 PM
MikeHTally's Avatar
MikeHTally
Holy cow! That's a lot of shrinkage. No blue smoke/oil in coolant?
Old Apr 5, 2010 | 06:41 PM
flwalks's Avatar
flwalks
My wife's Cadillac CTS would burn 2 qts between oil changes (common for the CTS to have sticky rings). About 500 miles before the last oil change I ran Sea Foam in the oil and it cleaned it out (oil was black as coal when change). Now 2000 miles into this oil change it hasn't burned a drop. I will run Sea Foam at the end (last 500 miles) of every oil change now. It's worth a try if you plan to rebuild anyway.
Old Apr 6, 2010 | 04:58 PM
super_b_car_guy
does anyone know if a 5.9 out of a 2000 druango will fit in a 2002 ram 1500?
Old Apr 6, 2010 | 06:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Likely so being the 02 Ram had a 5.9 but a little off topic for this thread.
Old Apr 6, 2010 | 07:07 PM
A05GSHO's Avatar
A05GSHO
How much sea foam did you put in?
