Thermostat
Old Apr 4, 2010 | 10:38 PM
Kevno6's Avatar
Kevno6
Default Thermostat
Changing thermostat tuesday, is there only a gasket on the thermostat or is there a gasket for the housing also. I can't seem to find one is. Thanks
Old Apr 4, 2010 | 10:58 PM
FireFighter's Avatar
FireFighter
From: The old famed Gen3 Broken Valve Spring Thread - https://dodgeforum.com/forum/3rd-gen-ram-tech/237316
Just on the t-stat. Just changed mine but I also put some gasket material, thin layer on the housing mating surfaces.
Old Apr 4, 2010 | 10:59 PM
Kevno6's Avatar
Kevno6
Thats the area is was wondering about, I remember the old gaskets from back when never changed this one. Thanks alot
Old Apr 4, 2010 | 11:00 PM
Kevno6's Avatar
Kevno6
Did you have any problem with housing bolts
Old Apr 4, 2010 | 11:10 PM
FireFighter
Here's the new one installed. The housing is recessed and the new gasket seats down inside, but still put some gasket maker on there to be safe. Yes, the lower bolt is a major pain if you don't remove the hose from the t-stat housing.
Old Apr 4, 2010 | 11:12 PM
FireFighter
Also, make sure you have the little bleeder pin in on top in the same position.
Old Apr 5, 2010 | 10:49 PM
Kevno6's Avatar
Kevno6
Changed stat, no freakin drain plug on radiator was a mess cutting hole in lower hose and thank god I had a spare. Dropped the old stat in water and boiled it and didn't even open, hopefully this solves my problem of losing antifreeze from pressurized tank hose. Thanks for the help
Old Apr 5, 2010 | 11:35 PM
RedTruck-VA's Avatar
RedTruck-VA
The thermostat I installed (180) didn't have a bleed hole nor the orignal I removed. Used an asprin to hold it open.
Old Apr 6, 2010 | 07:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Why would you cut the hose when you could just un-clamp it and pull it off? And I have never seen a rad without a drain.
Old Apr 6, 2010 | 08:36 AM
BEAR's Avatar
BEAR
EXACTLY! You cut a hole in it THEN had to unclamp it to replace it....... and No drain plug???
